dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > General Camaro Forums > Camaro ZL1 Forum - ZL1 Specific Topics
Old 05-31-2021, 05:44 PM   #1
shiner98
shiner98's Avatar
Drives: 13 AshGray M6 ZL1 w/Nav/ECF/Sunroof
Help: Sport Tour button modes won't work anymore
My 2013 ZL1's Sport and Tour modes will no longer activate. The car only has 15,000 miles and I've noticed the suspension now feels like a land yacht. I've tried unplugging the battery to reset the computer and I know I'm not in one of the 5 PTM modes which will deactivate the lights. Could my Magneto shocks have just gone bad from having the car sit so long? When I first put in and turn the key the Tour or Sport mode light will turn on for a sec then turn off so I know the lights work, but then when pushing either button it will not turn the light back on. I'm not getting a fault code for the shocks and I've run the OBDII with no codes either. I really hate to take it to the dealer so am hoping someone here has seen this before, thanks.
shiner98 is offline   Reply With Quote
Old 05-31-2021, 07:10 PM   #2
Bigtime53
Bigtime53's Avatar
Drives: 2013 ZL1
You said you unhooked the battery but for how long? That usually will take having the battery unhooked at least 12 hours [overnite] then hook it back up and it should correct itself. If not check your fuses one may have blown. Good luck.
Bigtime53 is offline   Reply With Quote
Old 05-31-2021, 07:34 PM   #3
shiner98
shiner98's Avatar
Thanks, I saw a tread on here for a related PTM issue that said to unplug the battery for about an hour, but will try it again overnight now. I had looked up the fuses closely in the owners manual but could not find one that could be related to this issue, maybe I just need to look again.
Old 05-31-2021, 07:38 PM   #4
Shodown
Shodown's Avatar
Drives: 2014 ZL1
Magrides are shot. Replace them with coilovers and thank yourself later.
2014 ZL1 M6: Roto Fab Intake, LS3 TB, Long Tube Headers, NPP, Mild 2 Wild, JMS BAP, SMG aux pump, ID 1050X Injectors, DSX Flex Fuel Sensor, 10.5" DSX Lower Pulley, Killer Chiller, Tuned by Ted at JRE, Pedders XA Extreme coilovers, Mickey Thompson Street S/S on Weld S71s
Shodown is offline   Reply With Quote
Old 05-31-2021, 08:39 PM   #5
rednecks70
Drives: 2013 AGM ZL1, '70 Chevelle 454
Hey Shodown, I saw your signature and very impressed with your numbers. Making 633 hp with a 10% pulley and headers is very impressive. Does the chiller play a big role in making that power?
Sorry, not trying to hijack the thread. Let us know if disconnecting the battery for 12 hours works!
rednecks70 is offline   Reply With Quote
Old 05-31-2021, 10:12 PM   #6
ZMEnow
Drives: ZL1, 2013, tri-coat-red, manual
A failed/leaking mag strut will not affect the PTM modes as it still has its 5 ohm residence to the control module.
ZMEnow is offline   Reply With Quote
Old 06-01-2021, 02:14 PM   #7
CJ27
Drives: Chevrolet camaro zl1
Agree. Unhook the battery overnight before replacing the mag rides
2014 Sliver ZL1. Built engine, Stage 1 Frankenstein heads, Magnuson, SW long tubes, AFCO H/E, She Gone cam, flex fuel sensor, meth injection. 820rwhp e85.
CJ27 is offline   Reply With Quote
Old 06-01-2021, 06:21 PM   #8
shiner98
shiner98's Avatar
Well overnight didn't work, still having the same problem. When I put the key in and turn it the Tour or Sport mode light will just blink once then will not turn back on after selecting the buttons.
Old 06-02-2021, 06:15 AM   #9
CJ27
Dang I was hoping that would fix it.
Old 06-02-2021, 12:11 PM   #10
RobZL1
fo'shizZL1
RobZL1's Avatar
Drives: 2017 ZL1
Note that he also is running e85.
2017 ZL1 M6 Black | Maggie 2650 // 103TB // Big Gulp
Past Rides-
2014 ZL1 M6 Red Hot | Tons of mods
2004 CTS-V M6 Silver | Many mods
1995 Corvette M6 Torch Red | A few more mods
1992 Camaro M5 White | A few mods
Old 06-02-2021, 08:00 PM   #11
rednecks70
Good catch, didn't see that, guess I should consider it in the future.
Old 06-03-2021, 03:05 AM   #12
Shodown
Shodown's Avatar
Drives: 2014 ZL1
It as also making that power on corn which is totally worth the money. The chiller definitely helps keep the power though. I can hot lap car at the track and make pull after pull on the dyno without worrying about high IATs. They are usually 25* below ambient at any given time. I dont lose power on each pull due to heat, it actually made more power on the dyno with each pull.
Old 06-04-2021, 10:28 AM   #13
JBZL1
JBZL1's Avatar
Drives: 2012 ZL1
You need to get the BCM refreshed, there could be an update as well. I had the same thing happen to me after my battery died over winter storage , tried everything but it didn't work... luckily my cousin is a tech for GM and was able to reflash it for me , after that it was back to normal! Also your speed is limited while your suspension has no tune ..
2012 ZL1 preproduction car #13
ROTO-FAB intake / IC reservoir , 2.85" upper , ported inlet
JBZL1 is offline   Reply With Quote
Old 06-06-2021, 01:09 PM   #14
shiner98
shiner98's Avatar
How do you reflash the BCM?
Yes this happened after the battery went dead on me.
