Old 07-17-2010, 09:12 AM   #1
quinthawk
Drives: 2010 camaro ss, 2012 ZL1, 2021 LT1
How much does summer heat affect HP
I have a maggie with 3.6 pulley, headers and an airraid intake. I went to
the track, temps were upper 80's with 75% humidity, my best run was a 12.5 @112+ (2.0 60ft time). I was on the stock pzeros. I was hoping to hit about 115 mph. All cars seemed slow. A 2010 camaro ss auto with an intake and tune ran 14.1 @101, DA was well over 3000. A 2010 Challenger with intake and tune ran 14.5 @ 97. Was it the heat slowing me down?
quinthawk is offline   Reply With Quote
Old 07-17-2010, 09:15 AM   #2
bi11ymc
"Silver Street"
bi11ymc's Avatar
Drives: 2010 2SS/RS L99
Heat kills horse power. Check out this thread and compare notes
Silver Street - 2010 Camaro 2SS/RS, SIM, Gray, Cyber Gray Rally Stripes, Polished Wheels, Automatic (L99) - 553 RWHP/510 RWTQ
CAI Inc., ARH LT Headers with Cats, Borla Touring Cat-Back; Pfadt Coil Overs, Sway Bars, End Links, and Trailing Arms; Comp Cams Blower Cam, Dual Springs, Push-Rods, and Lifters; GM LS2 Lifter Trays, 6.2 MLS Head Gaskets, Crank Bolt, and LS2 Front Cover; 3-Bolt Conversion Timing Gear, Katech C5R Timing Chain, ARP LS2/LS3 Head Bolt Kit, Melling Hi Volume Oil Pump, TVS 2300 Supercharger (Black); Build by Vengeance Racing; Custom Tune by Vengeance Racing
bi11ymc is offline   Reply With Quote
Old 07-17-2010, 01:40 PM   #3
alfie43
alfie43's Avatar
Drives: S/C 2SS/RS Camaro-6M-VicRed
Location: Alfie (Mariano) lives in Shelby Twp, Metro-Detroit
Send a message via ICQ to alfie43
An answer in two words: Big Time. Regardless of what type of induction and fuel delivery you have, i.e, forced induction, carburetor, FI, etc, we all have experienced how cooler temps make our cars run stronger. This is especially evident in the northern climates. Back in the 70s when I did a lot of drag racing, my ETs in Oct were .10 -.20 faster than my midsummer ETs...especially if I tuned it for the cool dense air.
I have had my Maggie on my Camaro for only a couple of months now, but I have already noticed that a forced inducted engine seems to be even more affected by excessive heat and humidity. More affected than a normally aspirated car.
My brother who has been driving several blown Mustangs since the early 1990s, says, "Watch when early November arrives, your car is going to run like King Kong."
Maybe someone else here can explain the science of why this happens to a greater degree on S/C engines.
Alfie
alfie43 is offline   Reply With Quote
Old 07-17-2010, 02:47 PM   #4
bi11ymc
"Silver Street"
bi11ymc's Avatar
Just a wild guess, but I believe it has to do with the density of the air. Cooler air is more dense, therefore more air per cubic inch, and more air allows for more fuel in the cylinder before combustion. More air and fuel, more power.
Old 07-17-2010, 02:50 PM   #5
2010 SSRS
2010 SSRS's Avatar
Drives: 3 V8 Camaros
wish this damn heat and humidity would go away.
Old 07-17-2010, 02:52 PM   #6
Luvpilot
Luvpilot's Avatar
Drives: GM
Zactley
Altitude works the same way.
I don't even like running mine hard with our 110+ temps. I've seen as high as 118 on the temp sensor already. I can only imagine what my IAT's are under full boost
Luvpilot is offline   Reply With Quote
Old 07-17-2010, 02:55 PM   #7
SGOS252382
SGOS252382's Avatar
Drives: 2010 Camaro 2SS/RS
Heat and humidity + altitude are a killer.
3000' DA is worth about .5 sec and 4-5 mph in trap speed (NA). Supercharged/Turboed cars are "usually" not affected as much by the altitude.
But there are other factors like a heat soaked engine (pulling timing), etc that can affect your times.
SGOS252382 is offline   Reply With Quote
Old 07-17-2010, 02:56 PM   #8
bi11ymc
"Silver Street"
bi11ymc's Avatar
Originally Posted by Luvpilot View Post
Zactley
Closer to see level, higher air density. More power.
How does the humidity affect the air? I am guessing water in the air also hinders combustion.
So, I guess the best place to drag race is in the desert (dry air) in the winter time at night (cold air) at sea level (dense air)
Old 07-17-2010, 02:56 PM   #9
alfie43
alfie43's Avatar
Yes, that's the line of logic that I was thinking. Back when I raced, we used to run the carb a little richer for the cooler temps...more dense air...it needs more fuel, right?
I didn't want to "pontificate" unless I knew for sure. Besides, my old science prof might be reading. What am I thinking? At my age, he has passed away by now.
Alfie
Dynamat and other sound heat and vib mats: Compare 2ndgenz28 Camaro DIY & HOW-TO instructions & discussions 40 07-30-2011 11:53 PM
Drivers Can't Rely on Summer and All-Season Tires, or Electronics for Control on Snow KILLER74Z28 General Automotive + Other Cars Discussion 25 07-22-2011 10:51 AM
ALMOST LOST MY SON TO HEAT STROKE TODAY "prima"Donna Off-topic Discussions 87 06-13-2010 03:57 PM
Camaro Custom Billet Fuel Door - Heat Metal Heat Metal Cosmetics and Lighting Modification Discussions 7 06-24-2009 04:27 PM
Possiblility of sightings this summer The_Stache 5th Gen Camaro SS LS LT General Discussions 15 07-17-2007 06:07 PM
