Old 08-17-2021, 08:34 AM   #85
RealQuick
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust
Yes sir… using #15 + #10 nozzles
RealQuick is offline   Reply With Quote
Old 09-10-2021, 09:29 AM   #86
RealQuick
Idle: https://vimeo.com/601884030
Dyno: https://vimeo.com/601865753
2nd gear quick hits on 8psi:
https://vimeo.com/601864419
https://vimeo.com/601863444
Old 03-07-2022, 10:15 AM   #87
RealQuick
Updates...
Installed BAP and removed those CAI's in the wheel wells (3" tubes with 4 90 degree bends) and fit stubby 4" filters right on the turbos. I am thinking this will really improve about and eliminate the power peaking super early (5500rpm). For those with Huron kits wanting to do this, I used K&N RU-2510.
2010 Camaro SS M6 - 416ci TT 989rwhp/1031rwtq @ 20psi
2014 ZL1 A6 Vert - Headers and CAI
Old 03-07-2022, 11:08 AM   #88
NoDakZ/28
NoDakZ/28's Avatar
Drives: 2014 Z/28 CTF
Originally Posted by RealQuick View Post
Updates...
I would run a waterproof filter sock on those if the car is daily/weekend car. You would really hate to suck in water...looks great though!
2014 1LE - Sold
2014 Z/28 #99008 CTF SIM
NoDakZ/28 is offline   Reply With Quote
Old 03-07-2022, 11:15 AM   #89
RealQuick
The car only goes out a handful of times during the summer/fall… only nice weather.
Old 03-07-2022, 02:17 PM   #90
dreksnot
Served USN - Atomic Chimp
dreksnot's Avatar
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10
I was using some little Spectre stubbies on mine. Was working fairly well for a short period. Bumped it probably pulling out my driveway on the curb and unknowingly apparently knocked the red filter off the turbo inlet. Turbo ate the red cover. Turbo didn't like the red cover. Spent long time picking red filter chunks out of turbo. Had to send turbo in for minor rebuild. There's a lesson in there.
In excess of 1,000WHP
LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates
dreksnot is offline   Reply With Quote
Old 03-07-2022, 02:35 PM   #91
RealQuick
That sucks.
Mine are tucked up quite high, so unless a rock whacked them on the highway I should be good.
Old 03-07-2022, 02:36 PM   #92
RealQuick
tucked up pretty good.
Old 03-07-2022, 03:00 PM   #93
stevieturbo
Drives: it changes
K&N's always seem to crush down like that...never liked them for a direct to turbo application.
Burger Tuning makes some compact air filters that are pretty good quality.
stevieturbo is offline   Reply With Quote
Old 03-07-2022, 03:15 PM   #94
RealQuick
In fairness to K&N, I had to man handle them to get them up. Those deformities are from me... the car hasnt fired up yet with them on.
Old 03-07-2022, 05:26 PM   #95
dreksnot
dreksnot's Avatar
My 65's and cold piping sit more awkward and yours. I had to trial and error K&N filter sizes to accommodate my 90* steel bend (same view as yours above). Needed as big of filter area to be able to pull lots of boost but still fit (the smaller one in the picture limited me to 14-15psi, the larger one up to 28psi, but the larger one is still smaller than the one AGP provides with their kits). Still too close to the headers so they cook a bit.
Old 03-21-2022, 02:54 PM   #96
RealQuick
Update... she rips with these stubby filters on! Did a couple quick 2nd gear hits... all over the road with the Nitto drag radials from a second gear punch at only 7psi. She definitely feels alot stronger than before with the CAI's.
Also, ordered ID1700's from RDP.
Looking for dyno time in May with the new upgrades (CAI delete, ID1700 and BAP) to see if I can surpass the 989rwhp/1031rwtq @ 20psi.
Old 05-17-2022, 12:25 PM   #97
a6d9cmro
Drives: Chevy SS
hi, any updates? I'm putting a Huron Speed twin kit on my 2017 Chevy SS with 6871 1.04ar turbos...so far, everything fits, but IMO the turbos look like they are a bit low. But, nothing is tight and just doing test fits.
Would you mind taking an under pic from the from of the from of the car to see how low the turbo's actually are? Really appreciate it.
a6d9cmro is offline   Reply With Quote
Old 05-17-2022, 12:43 PM   #98
RealQuick
Will be back on the dyno May 31st.
