02-16-2018, 01:02 PM | #29 |
Drives: 2010 2SS LS3, 2013 duramax Join Date: Nov 2012
Not an issue with the lsx iron block
ECS Ysi-B, cam, Tsp 2" longtubes, Squash dual pumps, Id1300s, meth, 4L80e, FTI 3600, ZL1 3.73 diff, BMR suspension, 15" conversion, weld rts mt 275 et street R. 9.6@147mph
02-16-2018, 01:07 PM | #30 |
Served USN - Atomic Chimp
Drives: 13 Camaro LSX434 TT M6, 21 ZLE A10 Join Date: Jul 2012
Been told by BTR that the LSR427 is fine for big boost also.
In excess of 1,000WHP LSX434 | AGP 65/65 TT | BTR Equalizer Intake | Trickflow 245cc cathedral | BTR custom cam | Cortex EBC | n2mb WOT | ID-1700x | Brisk GR12S | RPM Lv 7 TR6060 | AGP's Triple 525LPH Fore Fuel | Monster LT1-S Triple | 4.11 DSS Proform 9", CF driveshaft, 1400hp axles | Hurst Line Lock | MGW Retro Short Throw w/old skool Hurst T-handle | ADM solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Moreno camber/caster plates |
02-16-2018, 01:43 PM | #31 |
Drives: 2011 Camaro 2SS Join Date: Sep 2015
02-16-2018, 02:01 PM | #32 |
Drives: All things Turbocharged Join Date: Dec 2010
Decent amount of bad info and misunderstanding in this thread. Engine shops what to sell you more labor.
Take it for what it's worth- Do a 4.0" stroke aluminum block, (LSA is better) 417cid is the sweat spot. Stock heads with ARP studs will not lift with a good tune. You will have block problems before you lift heads. Now iron 6.0 blocks will support more than 4-bolt heads will take. The world is mostly full of bad tuners with crazy wives tale ideas and excuses. Never sleeve an LS block. KISS If doing an LS3 block anything, stop at about 1000wtq and always have a conservative tune. LSA block is about 100tq more. |
02-16-2018, 02:14 PM | #33 | |
Drives: 2010 SS Join Date: Jun 2015
02-16-2018, 02:39 PM | #34 |
Whats wrong with a sleeved block?
02-16-2018, 03:06 PM | #35 |
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
Just got off the phone with TSP, not a problem switching out to a 4.0 stroke (416ci), so that’s what I switched to.
02-16-2018, 03:12 PM | #36 |
The factory sleeves are ribbed on the outside and held in place while the aluminum block is cast around them. They are then one integral unit, literally woven into each other and designed as such to strengthen both. With the aluminum backing the iron sleeve and sleeve adding rigidity to the aluminum block. Machining the sleeve out ruins this and pressing in a smooth sided sleeve, and sandwiching it in place, is not ever going to be the same.
ERL went out of business specializing in this, I would assume because of the high failure rate, based on what we saw. More headgasket issues and more spun bearings and I conjecture was because the backbone of the block was taken out. Again KISS. Nothing wrong with the stock sleeves. They are brilliant and don't need to be super thick, by design. At the point you think you need sleeves, you actually need an iron block. |
02-16-2018, 03:15 PM | #37 |
02-16-2018, 04:08 PM | #38 |
Looking on this site, seems guys need atleast a 62mm turbine wheel to make my goal at 18-20psi. I only want to order the turbos once. I’ll research the 57/57’s some more. The goal is to use 93+meth.
02-16-2018, 04:20 PM | #39 |
We've have multiple guys make 1000whp on M/T car's with the 57/57 and on a stroker you will do it under 20psi. You would do it with more ease on 62/62, just a little lag.
02-16-2018, 04:22 PM | #40 | |
Drives: 2015 Camaro SS commemorative Join Date: May 2015
I see you dont offer the 57/62 anymore. any reason for that? is it a good upgrade to go to 62/62?
2015 Camaro SS, LS3 Stroker, PRC heads,CUSTOM CAM. AGP 68/68 with custom Hot and Cold side. Fore triple pumps, Holley terminator X. BMR drag suspension with carlyle brake kit. 15" ET drags and 17" skinnies. ZL1 3.73 gears , aluminum driveshaft. TH400 with circle D converter.
02-16-2018, 04:24 PM | #41 | |
I have a 57/62 AGP on a stroker and make around 18PSI at 60% duty cycle on the electronic controller. thats in 4th gear when its really loaded.
02-16-2018, 04:26 PM | #42 |
We still do. All the pull down menu's on the website are a little old, and some are new. We're really fined tuned exactly who should have what combos. On a M/T car these days, I'd go 62/62 if you want to easily hit well over 1000whp.
Thread Tools | |
