06-10-2017, 12:51 PM | #1 |
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
Does this look like spark blowout?
LS3
16psi 15 degrees timing 11.0A/F based on my wideband on the DP BRE7F @ 0.028" 93 + 100 meth #10 and #5 nozzles Clucth was slipping some on the dyno (thats why torque was low), but boost was very lazy and it was breaking up near peak power (up top). The smooth curves were 16psi @ .032 with less airflow (more restriction). I havev added about 20% more airflow with some tweaks to the turbo setup. **********Edit: Logs of run 68 attached************ Last edited by RealQuick; 06-14-2017 at 08:08 AM. |
06-10-2017, 12:54 PM | #2 |
Drives: 12 camaro ss, 72 chevelle, 91camaro Join Date: Dec 2013
that plug is too hot, throw some 8s in there and regap at .018...
12 camaro ss 427lsx, th400, f310 heads, crower shaft mounts, gpi specd solid roller, shearerfab 2k hp a/w, twin bullseye 88mm turbos, hughes pro ssx bolt together converter, holley dominator, 8.50 cert, backhalf, Ford 9", 33x17x16 tires, c16 fuel
06-10-2017, 12:57 PM | #3 |
06-10-2017, 02:41 PM | #4 | |
that does look like spark blowout or knock
06-10-2017, 02:45 PM | #5 |
Drives: All things Turbocharged Join Date: Dec 2010
Did you pull all 8 plugs? Do they all look the same?
06-10-2017, 02:50 PM | #6 |
Drives: 2013 ZL1 Join Date: Jan 2015
Just turn the boost down some and see if it cleans up and pulls to redline. If it doesn't then it's likely not plug blowout per say, could still be a bad plug, or a fuel issue or.......or......
2013 A6 ZL1
06-10-2017, 03:03 PM | #7 |
I only got pass side out. Need to drop the downpipe and pull the driver's manifold to get to them.
Unfortunately I wasnt able to run less than 13psi on the dyno, even the 13psi pulls looked like this. |
06-10-2017, 04:08 PM | #8 |
Drives: 2010 camaro ss Join Date: Jun 2010
That's how all of mine looked. Br7ef gapped at .032
I'm on 15psi with timing at 15 I believe. 100%meth. Not saying that this is normal but I'm also looking for a answer. I put new ones in at .028 to see what it does |
06-12-2017, 09:30 PM | #9 |
Hmmmm
Few ways to work through this probably.
I would consider turning down the timing. Turning down the meth and see what it will take. Then add one and then the other and see what it will take. Just a thought. |
06-12-2017, 09:35 PM | #10 |
Drives: 2010 2SS/RS Join Date: May 2010
What turbo kit you do have?
LME built LSX427 w/t all Callies internals| AGP 65/65 TT | Holley Sniper Intake | Brodix BR3/LME custom ported | LME custom cam | Pro EFI 112 ECU | ID-1700x | NGK BR7EF | AGP's-Fore Triple Fuel pump | Monster LT1-S Triple | ZL1 3.23 diff, CF driveshaft, ZL1 axles | Hurst Line Lock | MGW Retro Short Throw | Pfadt solid subframe mounts | Prothane Motor Mounts | Revshift Poly Trans insert | Ground Control camber/caster plates | Accelerated Racing Solutions tuned| God is too good! I don't deserve it, but I sure will accept it!!! |
06-12-2017, 10:41 PM | #11 |
'It's an experiment'
Drives: [COTW 2/09/15] '11 GPI LSA SC Z/LE Join Date: May 2014
747 RWHP 794 RWTQ
"Horsepower sells cars, torque wins races." - Enzo Ferrari See My Build: http://www.camaro5.com/forums/showthread.php?t=385577 |
06-13-2017, 11:16 AM | #12 |
06-13-2017, 09:46 PM | #13 |
This is mine.
06-14-2017, 08:09 AM | #14 |
Datalogs attached to post #1 of the run on the dyno. You can see the MAF is getting wacky in the spot where it goes wired on the dyno (5000+rpm).
