06-07-2017, 07:10 AM | #29 | |
Drives: 2010 Camaro 2SS M6 - Intake/Exhaust Join Date: Sep 2014
06-07-2017, 11:58 AM | #30 |
...not a marine biologist
Drives: 2012 Camaro RY SS LS3 Join Date: Mar 2013
Wow! I might consider doing the same. Any pic of the cutout on yours and what did you do with the existing wastegate bypass connected from the downpipe?
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com |
06-07-2017, 12:08 PM | #31 |
I will post some pics tonight. I just welded a patch panel over the hole in the DP. I am now dumping the wastegate to the ground in front of the k member.
06-07-2017, 12:13 PM | #32 |
Drives: 2013 Camaro SS Turbo Join Date: Apr 2014
Sucks about the clutch, was it worn out or abused? My monster lt1-s been hanging in like a champ
06-07-2017, 12:16 PM | #33 |
06-16-2017, 08:44 PM | #34 |
Any pic of the cutout?
06-16-2017, 10:09 PM | #35 |
I'll post some pics tomorrow, they are two cutouts on the S pipes that connect to the Huron y-pipe. I ended finding out why the cutouts died on the dyno... burnt wires from hitting the exhaust (I did a lousy job of tieing them up away from the exhaust).
06-17-2017, 09:39 PM | #36 |
Badlanz cutouts (i bought 3" by accident, so I made them work with the 2.5" pipes).
06-17-2017, 09:40 PM | #37 |
Not sure why the pic uploaded upside down?
06-21-2017, 08:56 PM | #38 |
Pulled the plug wires and found 4 out of the 8 were cracked. So with new plugs/wires and if clutch will hold, I should be able to improve on the 817rwhp.
06-22-2017, 06:52 AM | #39 |
Thanks. Can you hear the turbo low spool at idle with them open? Any concerns aggrevating the knock sensors and retard timing when using them? I had badlanz 3 inch dumping post header pre turbo and was obnoxiously loud inside.
06-23-2017, 10:01 PM | #40 | |
I am confused by your cutout.. you say it was after the headers, but before the turbo? That would mean it was on the hotside... if you opened it there the turbo would spool like poop. I must be missing something here... |
06-24-2017, 10:30 AM | #41 |
Drives: 2010 Camaro (M6) 1000+ HP SBE Join Date: Jun 2011
Ohhh Yes!! It's gonna be a Beast!
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam Brodix BP BR 3 Heads Kooks LT Headers and full 3" exhaust Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears McLeod RXT Twin HD Clutch & Upgraded Slave RPM Level VII TR6060 BMR Drag Suspension Package w/Strange shocks Carlyle 15" and M/T ET Street R radials 10.1 @ 143 mph 1/4 mile |
06-24-2017, 09:15 PM | #42 | |
