05-03-2016, 03:06 PM | #15 |
Too much is never enough!
Drives: AGP TT SS [COTW] 4/20/15 Join Date: Feb 2014
Unless your planning on four digit wheel power numbers there is really no point in the LSX. There are a ton of LS3's stock making the power your aiming for. You can forge some internals on an LS3 and your still good for 1000whp, providing you have assembled the right parts. I have seen a bunch of people lately wanting to go to an LSX engine and have power goals that are under 1000. IMO that's just a waste of money. A good engine builder will stand by their product should you have any issues once its installed and running.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread http://www.camaro5.com/forums/showth...55#post8107855 |
05-03-2016, 03:08 PM | #16 | |
I did it for the warranty. |
05-03-2016, 03:14 PM | #17 |
I know your reasons, but ADM would have stood by their built LS3. maybe not after 20k miles, but lets be realistic here. All the engine builders I spoke with, while they didn't offer a "Warranty", they did tell me if I purchased a motor from them, and it had a failure related to their workmanship, they would stand by it. Those people all have reputations to uphold. ADM I would imagine is no different. They build a ton of engines. Ask them how many of their built LS3's have failed...
05-03-2016, 03:18 PM | #18 | |
Well mostly due to budget. I hadn't had time to save anything back up after the blower. He made me a good deal for a nice forged stroker with my core as a swap. But, I didn't care for that much power. I'd be pushing the fuel system. Yada yada. So the Lsx was actually my "cheapest" fix. $5,600 for the b8 is a pretty damn good deal. Cheaper than most ls3 long blocks m |
05-03-2016, 04:35 PM | #19 |
Drives: Camaro Join Date: Mar 2013
I did the LSX swap because I wanted to keep the stock LS3 stock. It is sitting on an engine stand in my garage. Was it the cheapest way to go? No. But I still have my stock engine.
05-03-2016, 04:38 PM | #20 |
Drives: 2013 Camaro ZL1 Join Date: Nov 2012
Iowa
I'm also in Iowa and I sent my car to ADM a month and a half ago, only costing me $600 to get it there inside an enclosed trailer. Ask Andy to set it up for you. Although he is extremely busy with my car right now I'm sure he'll find the time to help you out. Sorry Andy, I had to throw that in there. Lol
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance 1000rwhp |
05-03-2016, 04:41 PM | #21 | |
And mine |
05-03-2016, 06:31 PM | #22 |
Drives: 2010 camaro ss, 2012 ZL1, 2021 LT1 Join Date: Oct 2009
Hey White1le, my wifes cousin, Bill Stoffel has mentioned he has a friend in Dubuque that has modded his camaro similar to your. Any chance you know Bill.
05-03-2016, 09:03 PM | #23 |
That name sounds very familiar. I'm terrible with names. Lol. Mine is pretty much the only one in town with this much done. Several ZL1's though.
13 ZL1 A6
05-03-2016, 10:23 PM | #24 |
Drives: Camaro ss 1le Join Date: Jan 2014
Andy just build me a LSX376 B8 few weeks ago as far as the wait yeah its heavier then ls3 block, but it is noticeable no i haven't notice a bit, and i am very happy i went this route after all.
05-03-2016, 10:31 PM | #25 |
05-03-2016, 10:40 PM | #26 |
I had a Lsa blower and we just use that one for now i took it from the other engine
btr stage 3 cam boost a pump Adm heat exchanger |
05-03-2016, 10:42 PM | #27 |
Have any vids? I'm doing the same cam
SLP supercharged 2013 SS/RS 1LE VR Full front half protected by Xpel PPF Instagram:@Failshift 565hp/560tq @8.6psi 1LE Owners Group: https://www.facebook.com/groups/559684050767758/ |
05-03-2016, 10:51 PM | #28 | |
