04-12-2018, 08:19 AM | #99 |
Drives: '17 ZL1 Join Date: Jul 2016
It really doesn't. The eLSD can't choose the wheel to send power to. It only has one clutch that is used to limit the slip. There's no magic in this diff. It's simply a computer controlled limited slip differential with some clever software behind it.
04-12-2018, 08:28 AM | #100 | |
The Wizard they got on my case says there is a bushing in bind and wants the tech to put the car at ride height and losen and retorque all the bolts. I am thinking to myself the Car has all Heim Joints except for 1 bushing on each side SMH.
www.jannettyracing.com
04-12-2018, 02:22 PM | #101 | |
Drives: Camaro Join Date: Mar 2017
19 ZR1 | 16 Viper GT | 09 Z06 | 94 LS1 GT | 16 Denali | 19 CTS
http://www.gonicd.com |
04-12-2018, 08:52 PM | #102 |
Drives: 2017 zl1 Join Date: Jan 2013
Mine does it also. I bought the car new in August and haven't taken it to the track yet because I don't feel comfortable with it. I thought it was me. As soon as I felt it starting to pull, I would get out of it.
04-13-2018, 07:41 AM | #103 | ||
Also Call GM Customer service and start a case on it, Something I should have done a week ago but didn't know since I have never has any problems with my GM vehicles the dealer couldn't take care of on the first try. The car was there since Wednesday, I was at the dealer last night, The Tech had the car on the alignment rack and was showing me how the alignment was off a bit and he was convinced that was going to fix it. I politely laughed and explained to him the reason the alignment is off a bit is because I changed the corner weights after I aligned it here. He replied well I have to go through this step Per GM, I said have at it. I explained to him the car has had 2 different alignment settings and ZERO affect on the torque steer. So he proceeded to do the alignment and was all proud of his work, He did a nice job I watched. He was crushed when we road tested the car, and now has a new found respect for my word LOL. So we pulled up the exploded drawings of the ELSD so I can get a better understanding of how it works, which leads me to believe that the clutch pack either does not have enough clearance in it or it stuck on. The clutch pack is located on the right side of the diff. So I took the car for now so he can try and get a GM Service Rep to come to the dealer and meet me there next week. Ted.
04-15-2018, 10:18 PM | #104 |
Drives: NFG17ZL1 Join Date: Jul 2017
My car has been doing it since new, but with the Dealer looking for obvious things they typically "can't duplicate". Thanks for helping pave the way. I will be taking the shop foreman for a ride next week so they can identify my concerns without beating on my car. I will provide feedback once I know more from my end.
04-16-2018, 07:21 AM | #105 | |
Squeeze the throttle and it moves to the left lane even if you hold the wheel perfectly straight. It takes about 1/2 inch of right rotation of the wheel to keep it in the same lane under acceleration then you have the same problem I have. They want to replace the torque to yield bolts, and torque them at ride height but I am laughing to myself thinking you guys are wasting time and effort chasing a ghost it is not in the suspension it is in the differential. If it where in the suspension or alignment the would not go straight when cruising. This is the Only car with this Diff and is the Only this diff has the capability to drive one axle with power pushing the car to the left lane. Ted.
04-16-2018, 07:57 AM | #106 |
Drives: 1970 chevelle Join Date: Aug 2011
My 2015 z06 has the elsd as well. I haven’t noticed anything abnormal when under acceleration with it. When I get the zl1 1le I will let you know if that does it or not as soon as the roads don’t have salt on them up here in nh.
On Order 2018 ZL1 1LE Garnet Red Tint Coat Metallic
MY Car 2015 Z06 Z07 Daytona Sunrise Orange Metallic Dads Car 2013 ZL1 vin 963 Crystal Red Tint Coat/Black Wheels Exposed Carbon Fiber Insert 6 Spd Manual Last edited by closs2sx; 04-16-2018 at 08:54 AM. |
04-16-2018, 09:10 AM | #107 | |
I used to be Dragoneye...
I'm surprised they haven't focused in on the diff, given the error code they recorded. |
04-16-2018, 09:28 AM | #108 | |
They cleared the code and it didn't return but they didn't put any miles on it either. maybe its back now that I drove the car. Ted.
04-16-2018, 10:06 AM | #109 |
Drives: 2018 ZL1 1LE (2)79Z28 72RS 67SS 69Z Join Date: May 2009
Mine does this too.
...has done this since I got past my break in period in July of 2017.
- Buttons and Skulls -
miss my annimated signature. |
04-16-2018, 10:16 AM | #110 |
Next Monday/Tuesday finally looks warm enough to try this and see if mine does it and I just don't remember...
04-16-2018, 10:21 AM | #111 | |
The more of us that notify GM the faster this will get resolved.
04-16-2018, 10:42 AM | #112 |
Wow...Hopefully you guys get this resolved. I'm not sure if it's worth it but maybe go out on your own tab and buy a new/used diff and see if that fixes it?
Stunned at how many problems keep popping up with this 6th gen ZL1. |
