Old 04-10-2018, 07:18 PM   #85
Mr. Wyndham
I used to be Dragoneye...
Mr. Wyndham's Avatar
Drives: 2018 ZL1 1LE
Originally Posted by JANNETTYRACING View Post
NO change what so ever.
They called today they want my car at the dealer so GM Tech support can link in to my car and look things over.
Personally I don't think it is computer/electrical related, I think it is mechanical and I need a new diff.
I don't think the diff is responding to commands.
And if I read right, the diff returned a clutch error code and they've got a new one on order for you?
Old 04-10-2018, 07:23 PM   #86
TMS
TMS's Avatar
Drives: 2018 ZL1 1LE - HBM, PDR
I too have been curious about how the eLSD actually works and how it compares to true torque vectoring differentials. I ran across what appears to be the patent application on the GM eLSD. Interesting read for inquiring minds.
https://drive.google.com/file/d/1pVh...w?usp=drivesdk
I am following this thread closely to pick up new knowledge directly on this steer problem and indirectly on the eLSD.
Good luck Ted. At least GM and dealer seems to be actively engaged to remedy.
JRE Tuned (HPTuners) | 15% OD (9.17" crank pulley) | TVS2300 Maggie Heartbeat Supercharger - 14 psi | E-50 (DSX Flex Fuel kit) | JMS FuelMax Fuel Pump Booster | LPE Big Bore High Volume DI fuel pump | LPE High Flow DI fuel injectors | LT5 95mm TB | RotoFab CAI | AEM X-Series OBD2 wide band gauge | Elite Engineering E2-X catch can | Borla S-type NPP Cat-Back 3" exhaust | Forgeline GTD1 5-lug Satin Graphite | SunTek wrap | C-Quartz Finest Reserve ceramic coated
TMS is offline   Reply With Quote
Old 04-11-2018, 08:00 AM   #87
JANNETTYRACING
JANNETTYRACING's Avatar
I called again they said they are not allowed to order a complete diff unless GM tech authorizes it after they run this test.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 04-11-2018, 09:06 AM   #88
Mr. Wyndham
Ted.
Ahh, Gotcha. Well - sounds worth the investigation. Thanks for keeping us updated!
Once it warms up around here, I'm going to have to try and test this out on my car...haven't noticed it before...so I don't know if it's there.
Old 04-11-2018, 09:14 AM   #89
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Car was less than 24hrs old when the problem appeared.
High end car, I'm surprised that GM wont take the car back and give you another one.
I'm sure they would love to do forensics on the car.
ZL1::J-E-T-S JETS JETS JETS
bobby35ny is offline   Reply With Quote
Old 04-11-2018, 09:24 AM   #90
JANNETTYRACING
Just dropped it off the Lead World class Tech is working on it.
Ted.
Old 04-11-2018, 09:30 AM   #91
Mr. Wyndham
Not a high volume car, and it doesn't sound like the car as a whole has a problem, just the diff. If this is anything like some of my past experiences, there will be a field engineer involved, shortly....
Old 04-11-2018, 09:58 AM   #92
bobby35ny
bobby35ny's Avatar
Drives: 18 ZL1 A10
Exactly! Not a high volume car. all the more reason to park it and tear it apart to find out what's going on. Hey I know that wont happen, just surprised that's all.
Old 04-11-2018, 01:28 PM   #93
waterman
waterman's Avatar
Drives: Grandad's C2 L89
Ted.
Continuing to follow with great interest.
Thanks for keeping us updated Ted.
2018 ZL1 1LE sw/PDR
Old 04-11-2018, 02:31 PM   #94
Ecchi667
Ecchi667's Avatar
Drives: 2016 Camaro 2SS, 6spd M
Tramlining (Tram-Lining - taken from Wikipedia because I got lazy): "Tramlining is the tendency of a vehicle's wheels to follow the contours in the surface upon which it runs. The term comes from the tendency of a car's wheels to follow the normally recessed rails of street trams, without driver input in the same way that the train does. The same effect is sometimes called Nibbling."
I get some tramlining in the Camaro. I believe it's due to having noticeably wider rear tyres. The 30mm difference between front and rear is a little over an inch, so noticeable.
Mentioning torque steer - that's more an issue for FWD cars. My Clio 172 Cup had it a little bit. It could technically happen in AWD and RWD cars, but not to the same extent. Best way I can describe that feeling is when you are accelerating a rear wheel drive car and you let go of the steering wheel, it pulls to the angle of the front wheels as they sit and drives straight from there. If you let go of the wheel in a front wheel drive car under those same conditions, it'll yank the front wheels to the angle of the rear wheels - straight ahead. Similar to coming into a corner too hard and locking the brakes up.
Question - when this lane switching happens, does the car actually accelerate, maintain a steady pace, or slow down? Rather than a slip, it sounds more like a lock to me - and I'd expect to see a sudden but slight drop in speed. The left of the car is locking up and that drag on the tyres is tugging the car to the left. The right is still moving freely, as it has no such resistance.
I'm assuming you've tried comp mode and completely disabled traction control to see if you have the same issue there? If the rear left brake was locking (or front left brake I guess) then it'd pull like that.
Just some thoughts. Good luck!
Ecchi667 is offline   Reply With Quote
Old 04-11-2018, 02:54 PM   #95
JANNETTYRACING
It is simply all the power is being applied to the right rear wheel under moderate acceleration pushing the car in the left lane.
Very light throttle cruise you can let go of the wheel.
Hard acceleration it spins the tires and goes straight.
Nothing is dragging or locking up car accelerates normally in all conditions.
Ted.
Old 04-11-2018, 07:44 PM   #96
Nick S
Nick S's Avatar
Drives: 2013 Camaro 1LE
Ted.
Hey Ted,
I was thinking about this the other night and was thinking about what you are guessing the problem is (only one wheel getting power). Wouldn’t rear wheel drive vehicles with an open diff (i.e. no form of locking differential) experience this problem all the time since they are always only getting power to one wheel? It just seems to me that if the root cause is all power going to only one wheel then open diff cars/trucks would have the same issue all the time. Am I not fully understanding an open diff?
Good luck getting your car issues resolved ASAP. Really sucks to get a new car and have issues like this already.
Nick S is offline   Reply With Quote
Old 04-11-2018, 08:40 PM   #97
*007
Drives: Getaway Special
Originally Posted by Can'tHave2MuchHP View Post
Ted's issue is separate from the "Floating" feeling that some/all? ZL1 owners experience. Thankfully GM has gotten the issue, but hopefully it gets resolved in some sort of a timely manner. I'd be pushing for a buy-back myself.
I haven't driven my ZL1 yet but I'm guessing it's guaranteed that I'll feel the rear end float.
Possible that both Ted's problem and the "floating" feeling are both related to a new fangled ELSD that maybe wasn't quite ready for production?
Actually, this “floating” is likely designed in to allow the ZLE drive experience to parallel that found in the W Body HC and attract those possible purchasers.
Sip:
*007 is offline   Reply With Quote
Old 04-12-2018, 08:13 AM   #98
JANNETTYRACING
Originally Posted by Nick S View Post
Hey Ted,
Even though an open diff will spin 1 tire it does not have the ability to apply power to 1 wheel.
This diff has the ability to apply power to one or the other axle through the ELSD.
Ted.
