05-14-2020, 07:10 AM | #1 |
Drives: 2016 Camaro 2SS Join Date: Jun 2016
Coolant level
Posted this about coolant levels on the maintenance forum with no response.
According to the manual 'Check to see if coolant is visible in the coolant surge tank . . . If coolant is visible but the coolant level is not at or above the COLD FILL line, add a 50/50 mixture of clean drinkable water and DEX-COOL coolant.' So with the engine cold on my car, the top chamber is filled just about to the top, above the COLD FILL line. The bottom chamber has very little in it, maybe 3/4", and I don't see any fill line. Is this normal? I've read some places that the bottom chamber should be half full, but reading the manual multiple times it seems like maybe I don't worry about the lower chamber unless the top chamber isn't full? The instructions given to add coolant look like they are for either if the coolant is visible but not at or above the COLD FILL line, or if there is no coolant is visible in the coolant surge tank. |
05-14-2020, 07:24 AM | #2 |
The way I read the manual and interpret the diagrams is that I should keep the upper tank completely full and the surge/overflow (lower tank) filled half way. A couple of years go the surge tank on mine was dry. I added coolant per the manual and have been good ever since.
05-14-2020, 08:09 AM | #3 | |
Great design from an engineering standpoint to ensure there's no air in the loop, but horrible from a owner/maintenance standpoint. This manual page shows the purge procedure as well as a good graphic of what the two tanks should look like under normal conditions (hot or cold).
05-14-2020, 08:09 AM | #4 | |
Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
Allez, read through that section of the owners manual. It goes into good detail and spells out exactly the procedure for adding coolant. I believe the bottom tank also has a cold fill line if you look closely.
2017 Camaro 1SS, M6, Hurst shifter, Hyper Blue, NPP, Gray Split Spoke Wheels
Best 1/4 Mile: 12.24 @ 115.9 mph |
05-14-2020, 09:42 AM | #5 |
This recent thread had much to offer on the same topic:
https://www.camaro6.com/forums/showthread.php?t=574138 |
05-14-2020, 01:07 PM | #6 |
Drives: 6 on the Flo' Super Sport Join Date: Jan 2011
8-)
05-14-2020, 01:26 PM | #7 |
Thanks everyone. I've read through that section of the manual several times; what confused me was that the only part where is says to add coolant to the bottom reservoir is when the top reservoir is dry (at least the way I was reading it). Maybe I was being too literal. Anyway, it's easy enough to add to the lower one, although my old eyes can't make out a fill line there.
05-21-2020, 09:27 AM | #8 |
Drives: Chev Camaro Join Date: Nov 2019
Just refilled mine after replacing the cooling fan, filled the top to the mark and bottom half way. Started the car, let the thermostat open, topped off the top tank, all good. used dexcool 50/50 premix from Peak I think was the brand.
05-21-2020, 09:36 AM | #9 |
TD
Drives: 2017 2SS, 2014 Mercedes C300 Join Date: Feb 2020
I always wondered why GM put a tiny funnel in a bag in my trunk. Turns out that little funnel fits perfect in the hole for the second coolant tank
05-21-2020, 10:48 AM | #10 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
As for the fill line for the bottom tank, if you look close enough, there should be a pinch in the plastic on the bottom tank near the halfway point, which you can use as a reference when filling up.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
05-21-2020, 01:59 PM | #11 |
Drives: 2013 C6Z06 Join Date: Nov 2016
That's for putting gas in the tank with a gas can. Capless system has a second sealing plate that needs to be pushed open by the small funnel.
05-21-2020, 02:12 PM | #12 |
My DEX-COOL 50-50 arrives tomorrow, so will add it this weekend.
05-21-2020, 02:21 PM | #13 |
TD
Well I'll keep using it for the coolant tank. Ive never run out of gas in my 36 years of driving.
05-21-2020, 03:15 PM | #14 |
Exactly - that's a good use for it!
