04-23-2020, 06:55 PM | #1 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
3 inch all round or NO?
I know a fair amount of boosted owners keep the 2.5 setup. You guys think I should upgrade to 3” cat back with custom mufflers for 800$-ish for just keep the 2.5” w/ my NPP muffler mod setup?
2014 SS 1LE Money Pit/ Forged 402
CAM 22X/24X, .619/.617, 113 LSA/ LS9 Heads FIC 1200cc/DSX Aux Pump//McLeod RXT Clutch 730whp: 630Trq |
04-23-2020, 08:25 PM | #2 |
Drives: 2011 Summit White Camaro SS Join Date: Feb 2018
I'm interested in the response to this question. I just ordered a full exhaust system minus the mufflers from ARH. I have a set of NPP mufflers already but I was wondering how much would the car benefit from the 3 inch piping or is it just for show.
04-23-2020, 08:33 PM | #3 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
3" spintech here....
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
04-23-2020, 08:40 PM | #4 |
04-23-2020, 08:54 PM | #5 |
Drives: 2011 Camaro 2SS LS3 Whipple Join Date: May 2019
There are gains to be had but i don't think it's necessary until you are pushing over 750whp. But no i couldn't tell you unless i upgraded. I was talking to Ted about it and i don't remember the numbers he told me exactly. 102mm throttle body i know he said world be worth 15hp. I want to say 2"headers and 3" exhaust he said would gain me about the same.
Whipple 2.9 CAI ID1050x injectors ZL1 Pump JRE FPCM JMS Voltage booster JRE Rough Idle blower cam BTR .660 springs CHE trunnion kit 1 7/8 Speed Engineering Borla Atak JRE scoop 1.5" lowering springs BMR trailing arms and toe links Cradle inserts 704WHP 603WTQ 93 octane
04-23-2020, 08:56 PM | #6 |
From previous threads I’ve read, and YouTube vids, there are benefits. However, to see the most result, you have to be pushing some good power. I’m going to be in the 750-800rwhp range.
I’m just curious to see why some guys here keep the 2.5 setup with their FI build. I did see these.. https://www.speed-engineering.com/sh...s-1le-zl1.html Not bad for 500$. I’ve had my fair share of bullet mufflers. Love the sound (depending on brand), didn’t mind the drone, but they did drone ALOT!!
04-23-2020, 08:58 PM | #7 | |
04-23-2020, 09:13 PM | #8 |
At 750-800whp it may be more. There is a full 3" set up for like $300 on amazon.... i almost bought it.
04-24-2020, 08:40 AM | #9 | |
I would have to swap out to the quad exhaust tips, and maybe the muffler. Great price though.
04-24-2020, 10:53 AM | #10 |
Drives: 2012 Camaro SS Join Date: Jun 2019
Upgrading the exhaust is my project for next year, I was thinking 1 7/8" LTs and a 3" exhaust. I wonder if the size of the LTs would impact your exhaust selection, if you have 1 7/8" headers go with 2.5" exhaust, or if you have 2" headers go with 3" exhaust. Would a 3" exhaust on 1 7/8" headers be a waste?
2012 Camaro SS LS3, JRE Scoop, CAI intake, Whipple Supercharger, Fast 85lb injectors, ZL1 pump, McLeod RXT clutch, MGW shifter, Stainless Power 1 7/8 headers w/HFC, Ridetech coilovers, BMR sway bars, trailing arms, toe rods, cradle bushing inserts, 2020 Speed Tuned.
04-24-2020, 12:21 PM | #11 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
04-24-2020, 12:32 PM | #12 | |
Who tf said you gained 50 w/ 3”... it was in 1 of the old threads. What muffler did you have? I think that should be the limiting factor, if they’re restrictive.
04-24-2020, 01:23 PM | #13 |
04-24-2020, 04:01 PM | #14 | |
Drives: 15 Camaro SS Join Date: Oct 2018
15 Camaro SS- GPI max top end, ESS Vortech V3 9psi, ID 1050s, ZL1 pump, JMS bap, Long tubes, Corsa extreme, Circle D pro 5C, 391 rear, DSS carbon drive shaft, poly cradle bushings, tuned by Ted Jannetty and much much more
Thread Tools | |
