04-09-2020, 07:05 PM | #1 |
Drives: 2013 2ss hotwheels Join Date: Aug 2014
Break in oil
Cam was changed.i m going to pic up car,d was told break in oil needed to be changed,is 60 miles to far to get it home to change it.
04-09-2020, 07:24 PM | #2 |
Drives: 2015 Camaro 2SS RS 1LE AGM Join Date: Oct 2013
Did they dyno tune it? Cause my shop changed the oil after dyno tune and was good to go.
Sent from my SM-G960U using Tapatalk
2015 2SS RS 1LE NPP/w Kooks headers, Procharged, ID1050X injectors, Katech belt tensioner, Mighty Mouse Catch Can, BMR subframe connectors, Matco driveshaft loop, AEM Wideband/Boost/Fuel gauges , Z/28 Splitter and Spoiler/w Wicker bill, Power Stop rotors and brake pads, MRR Z/28 Rep Wheels 20" w/p zeros 285 fronts and 305 rears, ZL1 addons Rock guards and Tow hook, Rear window louvers, Flags on the quarter windows and the moonroof, Billet aluminum door handles.
04-09-2020, 07:42 PM | #3 |
Drives: 2013 1SS 1LE Join Date: Jun 2016
60 miles is fine.... change when you get home
2013 1le- Katech 416 short block, TSP custom grind cam, LOD intake, cnc heads by F.ED., Nick William's 102mm T.B., CORN fed, Pedders coilovers. Performance street alingnment by Justin at Lake Country Alignment and dyno tune by Late Model Throttle.
603 h.p. 495 ft lbs tq. |
04-09-2020, 08:34 PM | #4 |
Drives: 2014 Camaro SS 1Le Join Date: Feb 2016
Send it! I’m assuming you got your car back?
04-10-2020, 03:21 AM | #5 |
Drives: 2015 Summit White 2SS 1LE Join Date: Feb 2012
I've never used break in oil.
04-10-2020, 07:56 AM | #6 |
Drives: 2013 Sparkly Red One Join Date: Dec 2018
If you have good oil pressure, send it.
04-10-2020, 02:01 PM | #7 |
I'm sorry what does send it mean?
04-10-2020, 02:08 PM | #8 |
Drives: 2012 Camaro SS Join Date: Dec 2019
Launch the care
Smash the gas Smoke the crap outta the tires from a dig Just fkn send it
2012 Camaro 2SS/RS - CSP Custom Cam 232/240 .615/.615 113 +3, Texas speed CNC heads, FTI billet triple disc converter, K&N cai, Katech ported TB, GPI Ported/rod modded manifold, Texas speed 1 7/8 headers, HFC, Flowmaster 2 chambers with x pipe, Mishimoto CC, MSD wires, Roto fab washer relocation, tru cool 40k trans cooler, apex scoop, Pedders extreme coil overs and much more!!
04-10-2020, 02:24 PM | #9 |
Sorry there was some confusion on my part. I told my installer I had just changed my oil before I put the car up for winter when I dropped car off.When he was done I he said he couldn't put tune on for another 4 or 5 days and i thought he said I'm going to need to change break in oil asap after tune which is why I was concerned 60 or 70 miles away. After I posted I found out he didn't use break in oil ( sorry) he just topped off my oil and (coated)cam and said I'd be fine driving home then change it.thanks for help people I don't know how attach link. On you tube: Cammed Camaro hot wheels
04-10-2020, 02:26 PM | #10 |
Now I know what send it means
04-10-2020, 04:26 PM | #11 |
You should press traction control twice, mash on the pedal, and drop the clutch..
