02-08-2012, 02:24 PM | #1 |
Drives: 2018 ZL1, 10L90E Join Date: Nov 2011
5" intake tube installed
I replaced the stock 4" plastic with 5" polished aluminum. I will post the details of the parts to do this later, if anyone's interested. The LS3 definitely likes the big gulp of air. Slight increase in response noticed.
2018 Denali HD L5P, A6
2018 Camaro ZL1, A10 2006 Corvette Z06, M6 (YouTube channel name-ANGRY6LITER for videos) |
02-08-2012, 02:26 PM | #2 |
Nice, that looks awesome
02-08-2012, 03:21 PM | #3 |
Drives: 2010 SS/RS Supercharged 427 Build Join Date: Nov 2010
Does the 5" intake tube look cool, of course it does. Trust me, I am not trying to rain on your parade here or even try to convince you to buy our CAI, I am just offering some food for thought because I live and breathe this stuff for a living. One BIG problem that I am seeing is that you are going to be sucking hot air into the engine. The IAT is much more relevant to making power than the volume of air you are bringing in when it comes to what you have set-up N/A. If you want do have a DIY kit (although I dont reccoment it) I would at least consider doing a heat shield of some sort to block off some of that engine bay heat. Just something to consider.
02-09-2012, 11:07 AM | #4 |
Here are the part numbers, vendors and prices...
www.SFXPERFORMANCE.com Spectre 5 Inch Mandrel 110deg Elbow With 6 Inch Leg - P/N: SPT96962 - $78 (But you might want to go with 120 degree bend - P/N: SPT96963) Spectre Vacuum Sensor Adapter kit – P/N: SPT9712 - $8 www.EBAY.com Ebay Store: Mandrel Bending Solutions 5" to 4" Gray 5 ply Silicone reducer coupler - Item #310371111356 - $30 for 2 www.HPS-SILCONEHOSES.com HPS Stainless Steel T-Bolt Clamp 5.24" - 5.55" for 5" inch hose - SSTC-133-141 - $12 for 2 HPS Stainless Steel T-Bolt Clamp 4.26" - 4.57" for 4" inch hose - SSTC-108-116 - $12 for 2 ADVANCE AUTO PARTS 3/8” fuel line hose - $10 (2) 5/8” fuel line hose clamps - $4 Cut off 1” from short end of aluminum tube and 5.5” from the long end. Drill a ¾” hole for the grommet and adapter for the “valve cover-to-intake” hose. I cut down the bottom half of the factory airbox (keeping the cold air duct installed) to shield the filter from some of the heat and let cool air flow in. I do plan on fabbing up a heat shield. I will follow up with pics when that is complete.
02-21-2012, 06:40 PM | #5 |
Some follow up pics... As you can see, with the factory fresh air intake tube connected to the modified factory lower airbox, the filter gets cool air for the most part. It is shielded from header heat, and the massive 5" intake tube allows for a large volume of air to be readily available for when you stomp the throttle.
02-21-2012, 07:18 PM | #6 | |
Drives: 2012 2SS/RS M6 Join Date: Jan 2012
Street Scenes billet grille (upper and lower)
Cold Air Inductions intake w/MPD gasket/seal kit MPD cowl induction hood RX Catch can Edelbrock shorty headers MSD wires Custom cat-back w/GMPP exhaust Hurst short-throw shifter GMPP splitter and high wing spoiler Lloyd's custom "SS" mats Showstopper under hood accessories |
02-21-2012, 08:22 PM | #7 |
Drives: 2SS/RS CGM CAMARO BEAST Join Date: Jul 2009
how are you getting more air? Can the 5" flow more that the stock restriction at the filter box or the opening restriction of the Throttle Body?
Intuitively, it seems to me, with the increaser then decreaser you have, you are going to lose air flow velocity and create turbulence which will mess you up.
2010 CGM 2SS/RS; 418 stroker; JE Forged Pistons (offset wrist pin); Forged Crank; upgraded valvetrain; Custom Comp Cams Cam; Kenne Bell 2.8; ID 1000s; Aeromotive Fuel pump with return; ARH Long Tubes; Spec heavy duty clutch; 3" Magnaflow Cat Back; Nick Williams 102 mm Throttle Body; Tune fixed by Dave Steck; 815 HP and 14 mpg
Upcoming-- Disintegrated drivetrain; Divorce if/when my wife catches on to my addiction |
02-21-2012, 08:30 PM | #8 |
Drives: 2012 ZL1 & 2010 2SS/RS Join Date: Jul 2009
A more normal sized/smaller tube will pressurize the intake air more allowing for a denser charge. Same reason a bigger exhaust is not better.
02-21-2012, 10:03 PM | #9 |
knows 2 facts about ducks
Drives: ...and they're both wrong Join Date: Aug 2009
Question: Where's your MAF sensor?
02-21-2012, 11:02 PM | #10 |
I haz camaro again :)
Drives: 2010 Chevrolet Camaro 1SS Join Date: Mar 2009
looks good man, just cause you didn't spend 400 bucks on an intake system doesn't mean it's not going to perform. i applaud you for your creativity, and i'll say it, an intakes an intake.
2010 Camaro 1SS(back in a camaro again, yessssss!)
2010 silverado z71 ccsb(sold, old dd) 2010 camaro1ss(sold, missed, will have another someday) |
02-22-2012, 12:17 AM | #11 |
Quit being a pu$$y
Dyno test!
02-22-2012, 09:15 AM | #12 | |
02-22-2012, 09:18 AM | #13 |
It is still there. The connector is rotated to the rear out of view of the pics. It is what the air filter is attached to.
02-22-2012, 09:18 AM | #14 | |
Thanks!
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
Injen Short Ram Intake Installed | sdmaro | Camaro V6 LLT Engine, Exhaust, and Bolt-Ons | 8 | 07-19-2011 08:09 AM |
Breath clean Air | GmPartsDirect.com | Interior Parts & Accessories | 0 | 03-30-2011 04:58 PM |
Help You and Your Ride Breath Easier | GmPartsDirect.com | V8 Bolt-Ons & Tunes | 0 | 03-30-2011 04:49 PM |
I F#@^up! Think I need a new intake tube for my Roto-fab CAI | King T | Camaro V8 LS3 / L99 Engine, Exhaust, and Bolt-Ons | 27 | 04-12-2010 10:52 PM |
