08-21-2019, 06:37 PM | #127 |
Dyno Show Queen LOL
It's done the LPE pump and injectors are for sale..
09-16-2019, 02:50 PM | #128 |
Dyno Show Queen LOL
This ought to go nicely with the DI system..
09-16-2019, 03:22 PM | #129 |
Drives: 2018 ZL1 Join Date: Mar 2019
Just PM’d you on the LPE pump and injectors
09-16-2019, 03:26 PM | #130 |
Drives: ZL1 1LE Join Date: Oct 2018
What injectors will you use with the port injection and are you running a double or triple in-tank pump?
09-16-2019, 03:31 PM | #131 |
Thank you Al Oppenheiser!
09-16-2019, 04:33 PM | #132 | |
Dyno Show Queen LOL
2 pumps
09-16-2019, 04:38 PM | #133 |
Wow...1050s for supplemental port and then did you go back to stock for the direct injection injectors?
09-16-2019, 05:21 PM | #134 |
Dyno Show Queen LOL
Yes
09-19-2019, 01:24 PM | #135 |
Drives: ZL1-1LE, 5th Gen COPO Join Date: Aug 2013
Very cool! I bet it helps keep the Valves nice and clean too.
09-19-2019, 01:53 PM | #136 |
Dyno Show Queen LOL
I hope so then I can get Tracey Lewis off my back for using a mighty mouse!
10-07-2019, 10:37 PM | #137 |
Drives: CTS V3 Join Date: Aug 2019
I wonder if the newer kits come with a MAP sensor extension now?
10-08-2019, 06:36 AM | #138 |
Drives: 2019 ZL1 Crush Join Date: Jan 2019
The "race" version does not, I just installed mine over the weekend.
I pulled it out of the loom and ran it across the front. |
10-08-2019, 07:12 AM | #139 |
Dyno Show Queen LOL
Did they take my advice and move the map to pass side if so no map would be needed.. I noticed it has provisions to do so.
10-08-2019, 07:16 AM | #140 |
No, it is about midway in between the last 2 intake ports on the DS.
No MAP needed? I go in for tuning next Friday, have 3.25, 3.00 and 2.75 pulleys on the stock lower. |
