08-31-2019, 12:14 PM | #3375 | |
Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
I'd rather see a clean sheet design with large enough bore centers to get a big bore and short stroke set up, which should rev and breath much better.
08-31-2019, 01:54 PM | #3376 |
Drives: 2018 ZL1 coupe Join Date: Nov 2018
Always difficult to tell from video, but it appears the GT350 is carrying more midcorner speed than the GT500... that would make sense with the weight numbers. But it doesn't bode well for beating a ZLE...
Can't wait to see an unbiased shootout... |
08-31-2019, 02:16 PM | #3377 | |||
Drives: 2017 Camaro ZL1 A10 Join Date: May 2012
However I believe those advantages start to wane and ultimately disappear once you get into V8s and displacement can be exploited. DOHC engines seem to be limited to around 5.5 when it comes to what you can stuff into a car realistically. Although the S197 GT500 was a 5.8. There is a 6.2 DOHC out there but I doubt those engines are practical for street use and I really doubt they would end up in a car. Back to the point. Where a DOHC V6 clearly outpunches the pushrod V6, the DOHC V8s struggle to keep up with the pushrod V8s as we have seen. And the cost factor is still there. So it isn't a power or efficiency thing because we've seen some of the fastest cars with the most powerful engines all using a pushrod setup. The only answer that I have heard is that the Euro market taxes based on displacement and GM has to comply. Therefore since they are limited in displacement they have to go with a 5.5. Basically the pushrod engine is getting handicapped from it's advantages and that is why we'll be seeing DOHC engines in the future. Quote:
This seems to be the answer. Not that DOHC engines are better. But that displacement is being capped or taxed and manufacturers have to limit the engine sizes. |
08-31-2019, 02:24 PM | #3378 | |
But to be fair, I asked if anyone could prove that a DOHC engine is superior when both engine's advantages and disadvantages are explored and not one person answered that a DOHC engine is better. |
09-01-2019, 11:07 AM | #3379 |
Iron fist, lead foot
Drives: 2003 Mustang Cobra Join Date: Jul 2013
Why can't we just do both, large displacement WITH dohc?
https://www.mercuryracing.com/mercur...-crate-engine/ Benefits of the DOHC four-valve design versus the typical LS pushrod layout include: •Improved intake and exhaust flow enables increased engine performance •Efficient, high tumble four valve combustion •Low mass, high stiffness design reduces stresses and enables smooth high RPM operation and long life •Improved drivability due to optimized camshaft timing at comparable horsepower levels
09-01-2019, 12:32 PM | #3380 | ||
Retired from GM
Drives: 2017 Camaro Fifty SS Convertible Join Date: Mar 2017
For the Ferrari and the McLaren, fuel economy may not be the issue so much as emissions. The bigger the holes, the more stuff you have to clean up when it’s all said and done. Ferrari and McLaren have to engineer to the really tough Euro 6 emissions standards, as well as have fuel economy measured on the WLTP fuel consumption standards. Much more difficult than the proposed US standards, including California. Smaller displacement is just the beginning of what they have to do to get there. There is a reason most European car brands offer 2.0L 4-cylinders, 3.0L 6-cylinders, and 4.0L 8-cylinders. They are trying to economize engineering effort to meet these restrictions by developing around 0.5L cylinder sets. That way, the same solution that works for a 4-cylinder can be scaled up to work for an inline 6 which is basically the 2.0L 4-cyl with two more cylinders added.
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8 LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | Last edited by Martinjlm; 09-01-2019 at 12:53 PM. |
09-01-2019, 05:14 PM | #3381 | |
Here is what I see. The move to a DOHC twin turbo setup to me does not seem to be a necessity given the advantages/disadvantages of it vs the advantages/disadvantages of a supercharged pushrod setup. These pros/cons include HP, TQ, efficiency, cost, maintenance, physical size, displacement, overall performance. I don't see GM ever saying "hey guys, we can't make any more power out of these supercharged 6.2 liter pushrod engines so we HAVE to switch to a DOHC TT setup". The switch seems more like they are being forced to do so based on a market they are trying to reach. Or a market that they have to satisfy. Displacement being taxed is the only explanation I could see for them having to switch. Because like I said, we have 6.2 liter supercharged pushrods engines making 650, 707, 717, 755, and 808/840 HP. Now if the market that GM has to reach limits displacement to, let's say, 5.5 liters, then GM would have to switch to a DOHC setup since a 5.5 DOHC would have more potential than a 5.5 pushrod. Catch what I'm saying? I'm saying that GM is not switching from 6.2 supercharged engines to 5.5 DOHC TT engines because the latter is a better platform when all the pros and cons are explored. They are switching because they have no other choice. Otherwise they would have switched a long time ago. So that is my point. And that is why I there has not been one answer from anyone to prove that DOHC engines are better than pushrod engines when both setups can be used to their advantages. If there was no cap on displacement and if the Euro market wasn't as influential on engine types as they are then GM would not be changing things. |
09-01-2019, 08:39 PM | #3382 |
Retired from GM
BlaqWhole,
There is not a ceiling on displacement. In China and in some countries in Europe there are displacement taxes. If there was a cap there would be no V12 Lambos, or Rolls Royces or V10 Audi R8. The issue is for mainstream cars which constitute the majority of most manufacturers portfolios. So the VWs, Audis, and even BMWs and Mercedes of the world have learned to develop engines that get best hp/l. That gets them to DOHC. And also to diesel. Many of the really impactful technologies in modern gas engines started as diesel technologies. Direct injection, turbocharging, multi-event injection, increased compression ratio. The other part of the equation, which you seem to be setting off to the side, looms much larger. The serious move to more strict fuel economy and emissions regulations is driving automakers to produce smaller, more fuel efficient and power efficient engines. The one place where displacement makes a definite difference, beyond the issue of displacement based taxes, is emissions. The bigger the hole, the greater the emissions and the challenge to clean them up. Thats why I am very certain that the next wave of engine development is smaller engines with stronger electric motor assist. And, as has been stated before, to get the most power out of a given displacement, DOHC is the way to go. Also, the flexibility provided by cam phasing, valve timing and valve lift and airflow management is simpler to achieve with multi-cam multi-valve engines. Again, an advantage for DOHC. If all GM has to be concerned with was making the highest powered engine they could fit under a hood, supercharged OHV makes a lot of sense. But they have to do that while meeting stringent fuel economy and emissions regulations. DOHC engines with variable valve train technology provides a better option to achieve that. ***EDIT*** "for" not "over"
A8 | MRC | NPP | Nav | HUD | GM Performance CAI | Tony Mamo LT1 V2 Ported TB | Kooks 1-7/8 LT Headers | FlexFuel Tune | Thinkware Q800 Pro front and rear dash cam | Charcoal Tint for Taillights and 3rd Brakelight | Orange and Carbon Fiber Bowties | 1LE Wheels in Gunmetal Gray | Carbon Fiber Interior Overlays | Novistretch bra and mirror covers | Tow hitch for bicycle rack | Last edited by Martinjlm; 09-03-2019 at 10:25 AM. |
09-03-2019, 09:05 AM | #3383 | ||
Drives: 21 Bronco Join Date: Jun 2012
09-03-2019, 09:11 AM | #3384 |
Drives: 80 Cutlass 403, 2010 FF RT Join Date: Jun 2014
Oldsmobile was set to unleash the W43 on the automotive world for 71 72 but GM changed direction and the work on this engine was shelved. This engine was Hemi and a DOHC 455 so you can have the best of both worlds limiting factor would just be size.
one engine the OW43 was able to get 700hp at 7000rpm https://www.streetmusclemag.com/news...hat-never-was/ Last edited by rocket403; 09-03-2019 at 10:01 AM. |
09-03-2019, 09:29 AM | #3385 |
W43 engine
09-03-2019, 12:27 PM | #3386 |
Thank you Al Oppenheiser!
09-04-2019, 11:38 AM | #3387 | ||
In reply, when I mentioned a cap on displacement I did not mean that GM could not go over a specific size. I meant that the more displacement an engine has the more they will be taxed on it. When you are mass producing vehicles a taxation of this sort might as well cap your displacement. That extra money is multiplied thousands of times. When these manufacturers discuss budgets and such all that gets counted in. Obviously. And that extra money doesn't just affect the Vette or whatever vehicle they are considering. it affects the entire company since they are looking at things as a whole. So there might as well be a cap on it. I'd wager that this was the intended purpose anyway. But that's a debate for a different day. So basically GM has to stay under a specific displacement to avoid being taxed extra. And even if it isn't ALL countries it certainly is enough that it will affect the entire lineup. Are they going to make specific engines for specific countries? Of course not. I'm not delving into an entire explanation of any of this. LOL!! Now that we got that out of the way... Like I said, since GM is now limited on engine displacement (as I explained), then it makes sense that they would switch to DOHC engines and also TT setups for a power adder. TT is the most readily available and used method that cars on this level are using. So to me all of this goes back to displacement limits and popularity of this type of setup among a huge market. Regardless tho, none of this matters as this is what the future has in store anyway. Quote:
09-04-2019, 11:54 AM | #3388 |
Anyway, the dealership called yesterday and left a message saying they want to put my C8 order in by the end of the day today. So it is bye bye to one or both of my current vehicles in the next few months.
