Roto-Fab
Old 02-24-2024, 05:34 PM   #1
Jimmy Hot-Wheels
Jimmy Hot-Wheels's Avatar
Drives: 2013 Hot Wheels Edition 2SS/RS
Center Cap for Factory Reproduction Wheels
Just bought Factory Reproduction FR27F Z28 replica wheels that came with plain black center caps. I was hoping to use my old OEM caps (black with silver bowtie) from my 2013 2SS HWSE part number 9594156, but they don't fit. Outside face is perfect, but they don't click in and stay. I was thinking maybe the Hot Wheels 21" rims had a funky center cap size, so...
I ordered a set of OEM GM caps part 22791586, but same issue. It's obvious that the flexible "teeth" inside clip ring diameter is bigger on the aftermarket cap than the OEM.
Does anybody know what OEM GM caps will fit the Factory Reproduction wheel center cap hole???
Jimmy Hot-Wheels is offline   Reply With Quote
Old 02-25-2024, 12:33 AM   #2
InFiD3ViL
InFiD3ViL's Avatar
Drives: 2010 CGM 2SS/RS LS3 Swapped A6
I don't know if it's the same with Factory Reproduction wheels, but my MRR 017's (6th gen 1LE reproductions) use the 6th gen OEM center caps. It may be the same for your wheels.
InFiD3ViL is offline   Reply With Quote
Old 02-25-2024, 12:13 PM   #3
Ernie70
Ernie70's Avatar
Drives: 2010 Synergy Green Camaro 1LT
CHeck Phastek ... I got mine through them when I got my MRR's
Ernie70 is offline   Reply With Quote
