12-28-2020, 10:41 AM | #1 |
Drives: 2021 1SS 1LE Join Date: Nov 2015
which race ramps for 1le
Which race ramps fit under a 1le? I did see the calculator on their site however I have my snow tires and wheels on so my ride height is a little taller right now, 245/45/19, so I can't get an accurate measurement. I was looking at the 67" xt and the 80" but would like to hear from people that have them. What did you go with and any regrets with the ones you picked?
12-28-2020, 11:52 AM | #2 |
Drives: ISO ss 1le Join Date: May 2018
The 56" fit by 1/4" under my 1LE. It was a bit close for comfort, so maybe go to the 67" route.
12-28-2020, 12:18 PM | #3 |
Looks to me that this jack would have far greater utility for racers https://www.quickjack.com/car-lifts/...EaAkJNEALw_wcB
'20 ZL1 1LE A10,
12-29-2020, 12:25 AM | #4 |
Drives: 2019 Chevrolet Camaro SS 1LE Join Date: Nov 2016
I recommend the two-piece 67" ramps.
12-29-2020, 10:52 AM | #5 |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
I have a '17 SS 1LE. The Race Ramps RR-56 work just fine.
Ideally, get the QuickJack mentioned also. I have both. The ramps are the best for quick items like oil changes. The QuickJack for more involved things. It takes a while to get the QuickJacks into position and located properly.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
12-29-2020, 04:37 PM | #6 | |
Drives: '18 1SS 1LE Join Date: Sep 2017
Store them under the car so when needed I just reach under and pull them out, throw the rubber blocks on the plates and lift the car right up. Drive in and out of the garage and don't know they're even there. Should mention the car has the bolt on ZL1addons lift blocks, makes lifting the car a snap.
'18 1SS 1LE Black, PDR
12-29-2020, 05:57 PM | #7 |
At some point I’ll get quick jacks. Just not in the cards right now. Thanks for the input everyone. I ordered the 67” race ramps because of the width and height.
