11-24-2021, 08:09 AM | #15 |
Drives: 2013 1ss Join Date: Jul 2012
I had the BMR setup on my 13 camaro when lowered and could not get to zero camber. Since then I raised my car closer to normal with the same setup and then lowered it back down about a half inch.
Moving it down about a half inch pushed the camber back to zero without changing anything else. Ths is not a solution but a reference that in this one case a half inch down made a .2 to .3 camber difference on my car. Slotting out the lower hole will most likely not do anything as the tabs and cam lobe on the bolts determine location. If you have full adjustment on the cam lobe location you already have full travel. |
11-25-2021, 12:21 PM | #16 |
SomeguyK
Drives: 2010 Black 2SS/RS Join Date: Nov 2014
I used SPC eccentric bolts on mine. Work perfectly.
TMS 427, Dart iron Block, Forged assembly, Frankenstien heads, AGP TT 62/62 BB turbo's, AGP/Fore triple fuel system, Tilton clutch, Holley 1 7/8 shorties, Technostalgia tail lights,Oracle, Aeroforce, MGW shifter,Flowmaster, Pegasus subframe bushings,BMR trailing & toe arms,Z28 UCA bushings,Zl1 rear sway bar,Prothane,BMR,Goodridge brake lines,Ridetech HQ coilovers,3.91,Trutrac,billet caps,DSS axles,HE offest,built TR6060,1LE diffuser,Havoc spoiler,SSclones,20in MRR 017, Pirelli P Zero, Nitto NT555RII
More to come. |
