07-25-2022, 03:04 PM | #15 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
Correct me if I'm wrong here, but isn't that what an alternator is for?
I had to google it to make sure I wasn't saying something stupid: Quote:
Has no one thought of putting an alternator into an EV? Now you decrease battery size because its no longer needed, cost on vehicle goes down, no more $30,000 range extending batteries needed. Less materials used in general. And all they have to do is engineer an alternator sufficient for the job. Granted I'm probably over simplifying things but the flow seems pretty simple to me. Battery -> Motor -> Alternator -> Battery Alternator only has to charge the battery at a higher rate than the electronic load on the battery.
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
07-25-2022, 03:12 PM | #16 |
Drives: RAM Join Date: Aug 2019
Ah yes, that looks the part. An EV version of a Malibu SS… POS
07-25-2022, 03:15 PM | #17 |
Drives: 22 1LE Join Date: Mar 2022
07-25-2022, 03:16 PM | #18 | |
Anyone want to guess how much horsepower the F150 Lighting motor produces? 426 hp I don't think the load on the motor is as high as you think it would be. By that logic our 6.2L V8's shouldn't have alternators, but they do, and they have 800 + or - cranking amps for short durations. I mean are my observations really that far off that there is something I'm not understanding?
07-25-2022, 03:26 PM | #19 | |
https://evbaron.com/why-dont-electri...e-alternators/ Our vehicles have alternators to convert energy from fuel into electricity. Cranking amps are a measurement for batteries, not alternators. An EV powering an alternator with a battery to then return the energy to the battery will have losses. |
07-25-2022, 03:36 PM | #20 | |
Very well then, I guess 200 miles per battery charge and 1 hour charge session after it runs out is much more efficient than a 450+ mile V8. Correct me if I'm wrong as I'm not an electrical engineer but last time I checked there was a device that multiplies electric output? I think they call it a "Voltage Multiplier?" That article describes the amount of power to run the alternator is more than the power the alternator would produce. So what reason would there be not to use a Voltage Multiplier?
07-25-2022, 03:43 PM | #21 | |
Drives: 2022 1SS Team Joe and Becky Join Date: Apr 2021
Power created by the alternator will always be lower than the parasitic draw of the alternator being spun by the motor, due to friction and heat. Plus, you still have to move the car. |
07-25-2022, 03:44 PM | #22 | |
07-25-2022, 03:45 PM | #23 | |
Drives: 2022 ZL1 M6 & 2023 Stinger GT AWD Join Date: Nov 2021
2023 Kia Stinger GT AWD - as a family car...
2022 ZL1, M6 as daddy's ass mover Charger sold! Better to sell, than waiting to be stolen... |
07-25-2022, 03:49 PM | #24 | |
Am I misinterpreting this? Also a Boost converter is not a Voltage Multiplier device. An alternator produces AC. A Voltage Multiplier device converts AC to DC and multiplies the DC Voltage many times. We are not changing the closed system's energy, we are converting its output to a higher Voltage which would be higher than the DC drain on the battery. (Theoretically assuming all factors are considered properly)
07-25-2022, 03:57 PM | #25 | |
07-25-2022, 03:59 PM | #26 | |
07-25-2022, 04:04 PM | #27 | |
Voltage multipliers and reducers are used when the voltage required by a device is higher or lower than normally supplied elsewhere in the system, such as thousands of volts required to fire a spark plug, or 5 volts to charge your phone, and converted from the base 12(ish) volt system in the car. |
07-25-2022, 04:19 PM | #28 |
Drives: 2022 2SS A10 Coupe. Black + Redline Join Date: Jan 2021
1. the "render" is nothing more than a photoshop of the EV Blazer. https://www.chevrolet.com/electric/i...g?imwidth=1920
2. whether intentional or not, Fluke is being a massive troll. |
