10-10-2021, 04:30 PM | #1 |
Drives: 2016 Camaro SS Join Date: Oct 2021
new to the Gen6 what are these?
One on each side zip tied up. What are they?
10-10-2021, 04:35 PM | #2 |
Those look to be the AFM actuators that were left connected, but zip tied out of the way as to not throw codes.
10-10-2021, 05:13 PM | #3 |
Drives: 2016 Camaro 2SS Join Date: Apr 2018
Yep it's the afm valves or the ones that go to the npp.
10-10-2021, 05:22 PM | #4 |
Drives: '17 2SS H50 Join Date: Mar 2016
Gonna assume the car is tuned, I had an A8 and it would throw a code when the AFM was detached.
We can see too far.
1100 - 5/26 0000 - Cancelled - 7/5 Contacted Becky - 7/1 2000 - 7/5 3000 - 7/6 3000 - 7/11 TPW 8/1 3100 - 7/18 TPW 8/1 3300 - 7/20 3400 - 7/21 Built - 8/2 - PS 1,182/1 of 699US 4300 - 8/3 5000 - 8/5 6000 - 8/13 |
10-10-2021, 05:23 PM | #5 |
Yeah, NPP probably wouldn't pop a CEL.
We can see too far.
10-10-2021, 06:14 PM | #6 |
Thanks I figured they were something to do with the original emissions control. The one on the drivers side was tied to the rubber part of the hose almost pinching it off so I moved them both to the fitting.
Yes the car is tuned. Can tuning stop the ecm from looking for them so I could just remove them? |
10-10-2021, 06:15 PM | #7 |
Probably, but I can't be certain.
We can see too far.
10-11-2021, 11:16 AM | #8 | |
Geezer_loves_Camaros
Drives: 2018 2SS, Black, A8 Join Date: Dec 2018
Yes, they can be tuned out, but it's in the fscm module. With HPTuners, you have to buy another 1 credit for that (if you haven't already for that car) to tune them out. If i recall correctly, you turn off all the cylinder deactivation exhaust flow valve codes, i think it was P12XX on the fuel control module. If it's not throwing codes now, probably cheaper to just leave them zip tied up under there, if you're ok with that. ;-) Edit: i just noticed you have a 2016. Not sure if you need the hpt credit, or not, for 2016. |
