Old 03-18-2020, 03:42 PM   #1
Snowwolfe
Drives: CTV5 V Blackwing on order
Battery tender
The Z I purchased came with the Chevy battery tender. I want to cut off the clamps and install a plug so I can leave the wiring harness in place on the battery "box" and route it out to the grill. This way I can connect or disconnect the charger without opening the hood.
I never seen a system like this Camaro. Are all the fittings on the positive side of the battery 'box" under the hood + connections? And same for the - side? Or just mount the - wire to any ground?
What are all the unused connections for under the hood ?
2022 CT5 V Blackwing with A10
2021 GMC Denali pickup with 6.2 and A10
2017 Ford Expedition
Snowwolfe is offline   Reply With Quote
Old 03-18-2020, 03:54 PM   #2
CW3SF
CW3SF's Avatar
Drives: 2019 Chevy Camaro ZL1 M6
I connected mine in the trunk. The rear deck still closes with the cord just running off to the side over the weatherstripping. I have been using this same method on a Jaguar F-Type for years with no ill effects.
CW3SF is offline   Reply With Quote
Old 03-18-2020, 05:59 PM   #3
sengli
sengli's Avatar
Drives: 2015commemorative vert 2SS
Ditto, wired mine directly to the battery, which is of course in the trunk. The plug resides in the trunk during operation. When I get home , I pop the trunk and plug in.
2018 ZL1 Bright Yellow, A10, PDR, sunroof, carbon hood, and dash- sold
2020 2SS A10 sunroof..shock and steel special-traded
2015 commemorative vert 2ss
sengli is offline   Reply With Quote
Old 03-18-2020, 11:19 PM   #4
1hprush
2018 ZL1 1LE
1hprush's Avatar
Drives: 2018 ZL1 1LE
Maybe this will help...
https://www.camaro6.com/forums/showthread.php?t=540177
1hprush is offline   Reply With Quote
Old 03-20-2020, 09:21 AM   #5
Snowwolfe
1Hprush
Thanks, it did
Old 03-21-2020, 12:51 AM   #6
1hprush
2018 ZL1 1LE
1hprush's Avatar
1Hprush
Thanks, it did
Old 03-21-2020, 07:30 AM   #7
Zigg L1
Zigg L1's Avatar
Drives: 2018 ZL1 Garnet Red Tintcoat A10
That's where I have my tender hooked up. Mine has a short stub wire with a disconnect. I leave it on all.the time and just plug it in when I need to
Zigg L1 is offline   Reply With Quote
