01-09-2019, 08:33 PM | #1 |
Drives: 2018 1SS 1LE HBM Join Date: Jul 2014
Any issues with headers and heat?
General question here. I'm installing headers next week and was curious if there are any issues with heat. I've seen some posts about melting wires, etc. Obviously need to zip tie as needed to keep things out of the way but when I spoke to the sales guy at Kooks and asked him about the spark plug boot protectors, he said in his honest opinion they weren't needed. Any thoughts on that?
01-09-2019, 09:26 PM | #2 | |
Drives: 2017 CAMARO 2SS Join Date: Jan 2017
I just got myself some MSD wires just to be sure. On my driver side 2 of the 4 plugs touch the header. I added the sleeves for the mean time but I would just get the msd ones just to be sure. They are 80$ and look cool too |
01-09-2019, 10:08 PM | #3 |
Drives: 2018 SS 1LE Join Date: May 2018
ARH 2x3” installed and I don’t see a reason to be concerned with OEM plugs.
🌽 Sauced, 2018 SS 1LE - 123mph @ 5,000 DA
ARH 2”x3” FULL System, Pray Ported MSD Intake Manifold, Pray Ported GM 95mm TB, RotoFab CAI, DsX e85 Kit, MightyMouse Catch Can, NicD Tune https://instagram.com/corn_sauced?ut...d=o0ako89uurwl |
01-10-2019, 06:20 AM | #4 |
Thanks for the replies guys. Appreciate the input and advice.
01-10-2019, 06:41 AM | #5 |
Drives: 2018 2ss 1le Join Date: Jan 2018
I got the boots figure it couldn't hurt..
I saw a dyno test where the car lost 10 hp with msd wired, maybe just an anomaly but stock wires work fine..
2018 2ss 1le roto fab dry, Stainless works 1 7/8 lt to 3'" x pipe with highflow cats to stock npp, soler 95mm t/b, edelbrock 2300, LT4 fueling , jms bap and dsx flex fuel, 618/620 on e45 rwhp
Jannetty Motorsports tuned |
01-10-2019, 08:17 AM | #6 |
Drives: 2015 Camaro 2SS 1LE Join Date: Apr 2015
I burned halfway through one of the stock wires a few months after putting on headers which caused a random misfire. Was a fun thing to hunt down as it was throwing a CEL. I now have MSD wires and much prefer them as you can bend them away from the header.
2015 2SS - Base A6 - Sold/Brother/Traded
2016 Camaro 2SS - A8 | MRC | NPP | 725rwhp - RIP 2015 2SS 1LE - RS/Sunroof Mods: Headers, Borla ATAK, intake - Sold 2018 M2 Exec - Current |
01-10-2019, 08:53 AM | #7 |
Yea there are heat issues with headers. The starter, plug wires, and wiring harness on passenger side need to be addressed or you will have issues. Not a big deal if you know that going into the project.
2016 NFG 1SS A8
01-10-2019, 09:25 AM | #8 |
the starter is already covered in heat shielding so I didn't address it....
hope that is ok
01-10-2019, 09:40 AM | #9 |
Drives: 2016 Camaro SS Join Date: Sep 2018
01-10-2019, 10:18 AM | #10 |
Drives: SS 6 speed of course Join Date: Jan 2016
It will cook, the starter and part of the header need to be wrapped. IMO of course.
01-10-2019, 10:23 AM | #11 |
Agreed. Gotta wrap them if u don’t have a coating
01-10-2019, 11:24 AM | #12 |
01-10-2019, 11:28 AM | #13 |
Nothing on mine is wrapped and I haven't had any issues with anything, yet. I'll cross that bridge when/if it arises.
01-10-2019, 11:28 AM | #14 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
All I did on mine is rotate the wire where it plugs into the coil just enough to take the slack away from the header. Ez as that
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
