12-01-2020, 05:44 PM | #1 |
Drives: 2023 ZL1 Convertible Join Date: Jan 2009
Is Stealth Mode Available in the LT1 Trim with NPP?
Hey guys, question for all, I am looking at an LT1 trim camaro with the NPP exhaust.
Is the "stealth" mode available under the touch screen? As many others, I do not want to upset the neighbours at 5AM Or is this a SS thing only? Cheers, Jason
2022 Equinox RS
2023 Trailblazer RS 2023 ZL1 Convertible |
12-01-2020, 06:10 PM | #2 |
Theoren Hanks
Any Camaro with the NPP option should include all 4 of the exhaust modes (stealth, tour, sport and track). Either tied to drive mode or changed through the settings on the screen
12-01-2020, 06:13 PM | #3 |
Thank you for the info......It would actually be a deal breaker for me if it did not have it in the LT1 trim......too many houses close together where I live and it would echo and reverberate everywhere...lol
2022 Equinox RS
12-01-2020, 06:28 PM | #4 |
Drives: 2021 Camaro LT1 Join Date: Sep 2020
I don't have track mode on my 2021 LT1. Even with mine set to sport is it no loud while just driving thru the hood at normal speed.
12-01-2020, 06:29 PM | #5 |
But you can confirm you have stealth?
Jason
2022 Equinox RS
12-01-2020, 07:11 PM | #6 |
Even if it doesn't you can tune any of the modes to be "stealth" with HPtuners.
2016 NFG 1SS A8
12-01-2020, 07:11 PM | #7 |
Drives: rally green LT1 manual Join Date: Jul 2018
LT1 has stealth, tour, sport, and auto (follows drive mode). It does not have a track option. Stealth really quiets down cold start, which is pretty loud in tour or sport. Only catch is you have select stealth mode manually in the vehicle settings every time you want to use it.
12-01-2020, 08:11 PM | #8 |
Drives: 17 2SS, 8L90, Cam, Heads, E85 Join Date: Dec 2016
Even with "stealth" mode on (valves closed 100%) it is still pretty loud in my opinion on startup, enough so I could see some do-gooder neighbors still getting mad. The loudness is made worse on a cold start since it retards the injection and spark timing and increases RPM and throttle on cold starts to help warm up the cats. The retarded timing (in my opinion) makes the exhaust louder as well.
I can't believe GM let the Camaro with the NPP out of the factory as loud as it is during startup, but that is what it took to meet cold start emissions I guess and there's probably no immediate noise level requirement. I've never heard a non-NPP in person but I would imagine it is a lot more quiet, especially during the initial startup rev up. Also I believe the stock tuning opens the valves during startup for the supposed "cool rumble effect". Although I can't remember it might close during startup if you force stealth mode, which you would have to force it through the menu, since I think it defaults back to tour mode (where the stock tuning sets the NPP valves fully open on startup) (like 6sigma said above). HP Tuners can set the startup rumble and customize the opening on all the modes however you want it though. |
12-01-2020, 08:41 PM | #9 | |
Drives: 19 Chevrolet Camaro 2SS 1LE Shock Join Date: Apr 2020
M4 cold starts are even louder.
Current:
2019 Chevrolet Camaro 2SS 1LE M6 Shock GM Performance Intake and that's it, because driver mods before car mods Past: 2009 Mazda RX-8 GT M6 Velocity Red Mica (Sold) 2015 Chevrolet Corvette Z51 2LT M7 Velocity Yellow Tintcoat (Flood totaled) |
12-01-2020, 08:56 PM | #10 |
Drives: 2021 LT1 6spd Join Date: Nov 2020
LT1 has Stealth, Sport, and Track.
I believe the Snow/Ice setting will put you on Stealth without choosing through the menus.
Current: 2021 LT1 Camaro, 6spd, Crush, Corsa NPP, GMPP CAI, Soler Performance Throttle controller
Previous: 1997 V6 Camaro, 5spd, Black |
12-01-2020, 09:50 PM | #11 |
Drives: 2020 Camaro LT1 Join Date: Nov 2020
I don't have a stealth mode in my 2020 LT1. Have Tour, Sport and Snow/Ice...Snow/Ice and Tour sound exactly the same to me
12-01-2020, 10:18 PM | #12 | |
https://www.chevrolet.com/content/da...art-072319.pdf
12-02-2020, 02:50 AM | #13 |
Drives: 2020 Camaro LT1 Join Date: Feb 2020
12-02-2020, 07:32 AM | #14 |
Drives: 2023 ZL1 Vert M6 "Sharky" Join Date: Mar 2020
FWIW,
My 2020 SS with NPP is just as loud on startup no matter what mode I turn it off in. And it will not let me change modes unless the car is started. |
