05-12-2018, 06:02 PM | #1 |
Drives: 17' 1SS 1LE GBA-Black Join Date: Mar 2017
Voltmeter Gauge - Did I get it right?
Trying to understand the movement of the voltage and the reasoning behind it.
Can anyone confirm the following: Bat. is in good condition, fully charged: Voltage is ~ 12.6-14 V, meter is located on the left side of the "Normal condition" area. Bat. is not fully charged, not so good condition: Voltage is ~ 14.5-16 V, meter is located on the right side of the "Normal condition" area. As the Bat. power decreases / power is drawn: Alternator compensates by upping the the charge and then we see the meter move towards the higher side of the scale = towards the right area. As Bat. power increases again and Bat. condition improves: Alternator does not compensate and then we see the meter move towards the lower side of the scale = towards the left area. |
05-12-2018, 06:05 PM | #2 |
LT4 M6
Drives: 2018 ZL1 1LE Join Date: Nov 2010
Sounds good to me.
05-12-2018, 06:13 PM | #3 |
Drives: 2021 Tesla Model 3 LR Join Date: May 2016
Pretty good. Anything higher than 12.5v means it’s charging since the battery is 12.5 volts.
And if you hold the start button for 5 seconds without pressing the brake and put it in accessory mode, then you see the battery’s true charge state. Engine running= the voltmeter is a charging status gauge. Engine not running= reading the actual volts of the battery. Last edited by ChevyRules; 05-12-2018 at 07:06 PM. |
05-12-2018, 06:47 PM | #4 |
Thanks for responding with useful info
05-12-2018, 08:47 PM | #5 |
Drives: '18 1SS 1LE Join Date: Sep 2017
I've noticed during city type driving the voltmeter is on the left side, and while cruising on the highway it's on the right side.
Also while "city" type driving and when decelerating, the meter will go from the left side to the right until you touch the gas again. Almost like the alternator is going full charge to add load to slow the car. Kind of like regeneration in a hybrid, using inertia for free energy. This voltmeter doesn't follow traditional voltmeter trends. Voltmeters use to go up some with rpm, drop a little at idle. They would start a little low after start up as they were recharging the battery, then climb up as the state of charge increased. Higher voltage needs even higher voltage to increase charge rate.
'18 1SS 1LE Black, PDR
05-13-2018, 09:29 AM | #6 | |
I guess that it is correct to assume that when the needle is in the left area, the alternator is charging less, while when the needle is in the right area, charging is increased. |
05-13-2018, 09:39 AM | #7 | |
If you want to see the state of the battery, when the car is off hold the start/stop button for 5 seconds without pressing the brake pedal( which of course would start the engine) and put the car into accessory mode. The voltmeter will then tell you the state of the battery. |
05-13-2018, 11:41 AM | #8 | |
This is a good method of testing the Bat. Actually, I did not know how to enter ACC and wanted to do it ever so often - I.E. to change setting quietly, not having to start the motor to do it |
