Go Back   CAMARO6 > Marketplace > Sponsors Classifieds > Exterior Parts & Accessories
Old 12-02-2021, 11:07 AM   #1
PFYC
PFYC's Avatar
Drives: Yes
Vertical Lambo Doors Conversion Kit For 2016-2019 Chevrolet Camaro
Product Description
PFYC is pleased to offer this vertical door kit for your 2016-2019 Chevrolet Camaro. This Lambo Door Conversion Kit is made specifically for your vehicle. Vertical Doors Inc. manufactures only the best, highest quality, strongest, and most affordable kit and ensures high quality. Our line-up includes all of the major vehicle manufacturers. Our system is everything you need for a successful, reliable and cost effective conversion in a minimum amount of time. Vertical Doors, Inc. kits are proudly made and patented in the United States. Get your kit today and install it so your 2016-19 Camaro will stand out from the rest of the crowd at the shows and cruises.
This VDI kit is easy to install, and is also easy to operate. Basically open your door like normal until it stops at a predetermined position, then raise your door. Every kit comes with a shock that will take most of the door weight making it easy to raise the door up to the vertical position. Your 2016-2019 Camaro will keep its factory look and feel while you are driving but the moment you stop and raise your doors you will experience a whole new level of attention that no other upgrade can give you. Fits all models.
Every Kit Includes:
2 Gas Shocks
2 Vertical Doors, Inc., Lambo Door Hinges (one for each side)
All Mounting Hardware
Direct "Bolt On" Hinge Kit
Mounts to Factory Bolt Pattern
Made in the USA from Domestic Hardened Steel
Patented in the USA
Completely Reversible
Application
2016 2017 2018 2019 Chevrolet Camaro
PFYC is offline   Reply With Quote
Old 05-17-2022, 05:26 PM   #2
PFYC
PFYC's Avatar
Drives: Yes
Thank You for shopping at https://www.pfyc.com/vertical-lambo-...et-camaro.html
