02-16-2021, 06:44 PM | #1 |
Drives: 16 Cadillac ATS A8 Join Date: Jan 2021
Boost inHg/psi
What is considered a normal reading at idle for a boost inHg/psi gauge to read?
02-16-2021, 07:32 PM | #2 |
I am referring to a Aeroforce interceptor scan gauge.
02-16-2021, 08:59 PM | #3 |
I dont use an aeroforce gauge, but my Prosport typically hangs around -18psi at startup, -22psi at warm idle. Peaks 27psi Tapped at the throttle body spacer.
02-16-2021, 09:51 PM | #4 |
https://www.dropbox.com/s/x3194jbo8c...91643.jpg?dl=0
Sorry, I still haven't figured out how to post a picture. |
02-17-2021, 09:29 AM | #5 |
Prosport gauge.. mine will hang around -16 to -18 mostly. But while driving will see between -25 to +27 pressure fluctuating. It think it will also depend on your tune, tap location, and ecu idle tables. My idle tables are set low so it gets a heavy vacuum reading.
02-17-2021, 10:17 AM | #6 |
Okay thank you for the info
03-10-2021, 04:58 PM | #7 |
Drives: Chevy camaro Join Date: Jul 2019
Generally its in vacuum in idle. General good vacuum should be between 17-22 in Hg
2019 Camaro 1 LT 2.0 Riverside Blue Metallic, ZZP strut bar, K&N intake, ZZP catted DP, MRT axle back, Injen IC piping, Trifecta Elite tune, zzp heat shield, turbosmart diverter valve.
Knockoff zl1 sideskirts, gm front chin spoiler, 1le blade spoiler, diode sides, 20" staggered Asanti black labels, azenis 510 245/40/20 fronts, nitto 555 g2s 275/35/20 rears. |
