09-18-2020, 08:51 AM | #29 | |
IMO the Weapon X kit is the nicest one out there. They are pretty much plug and play. They also come with a diverter so you can still use the factory heat exchanger and they have a coolant temp sensor. |
09-18-2020, 10:13 AM | #30 |
Dyno Show Queen LOL
I plan to make a step by step install guide
12-24-2020, 09:48 AM | #31 |
Dyno Show Queen LOL
Drivers side easy cheesy the module mounts to the cross member in the qtr panel you can make a plate tho mount to module or you can use 2 out of the four bolt to mount to the cross member.. passenger's side kinds a pain. I made a bracket to relocate the fuel panel. The module attached to fuse panel mount upside down right above the fuse box.
12-24-2020, 01:16 PM | #32 |
Petro-sexual
COOL STUFF EDF'!!!
12-24-2020, 07:07 PM | #33 |
Drives: '86 IROC-Z '18 ZL1 Join Date: Jul 2019
I really want to do this but I've read, atleast the ones in AZ, it hurts regular ac performance and doesn't do much in the summer.
12-28-2020, 06:19 PM | #34 | |
12-28-2020, 06:24 PM | #35 |
I have a custom 2 gallon tank and use a second oem intercooler pump after the tank under the rear bumper. With the footage of the 3/4 hose it comes to about 3 gallons total
12-28-2020, 06:39 PM | #36 |
12-28-2020, 08:29 PM | #37 |
Dyno Show Queen LOL
Its usually because the exchanger is still hooked up is why it doesn't do much. The exchanger actually kills the performance of the chiller and its best to add a bypass it.
