06-06-2020, 09:04 AM | #1 |
Drives: 2016 2SS Join Date: Mar 2019
342 REAR GEAR W/A8
I have a 2016 SS A8 and am thinking of changing the OEM rear gear to 342. Anyone on here ever done this? The car is street driven some but mostly drag raced.
06-06-2020, 09:58 AM | #2 |
06-06-2020, 03:23 PM | #3 |
Drives: 2016 2SS Convertible Join Date: May 2012
There aren't any aftermarket gears for the 6th Gen Camaro. The ring gear is welded onto the carrier. You have to swap out the entire differential if you want to change gears.
06-06-2020, 07:41 PM | #4 |
06-06-2020, 08:35 PM | #5 |
06-07-2020, 06:49 AM | #6 |
Aren`t the Corvette rear ends the same stuff?
06-07-2020, 09:05 AM | #7 |
No Corvette diffs won't work.
2016 NFG 1SS A8
