02-05-2011, 03:49 PM | #1 |
Mrs. Bunny to you
Drives: Not a Camaro Join Date: May 2009
LOWERING SPRINGS HELP!
I got my lowering springs installed, and I hit a small bump on the way home, I wasn't going very fast. From that point on the front two springs have been making a creaking noise everytime I hit a bump as the car is coming down.
I called the company who installed it and they said bring it back. Skip thinks they didn't tighten the strut enough... Any advice will be very appreiciated. Should it be okay to drive? Thanks in advance. |
02-05-2011, 03:50 PM | #2 |
PWA Relapse
Bring it back.
- X
2017 1LT/RS A8 Hyper Blue Metallic |
02-05-2011, 03:51 PM | #3 |
Mrs. Bunny to you
02-05-2011, 03:52 PM | #4 |
PWA Relapse
02-05-2011, 04:10 PM | #5 |
Back on the dino-juice
Drives: '10 LS + a few more Join Date: May 2010
Should be safe to drive it down to them. How long were the new springs on?
I wake up in the morning and I piss excellence.
-Ricky Bobby America is all about speed. Hot, nasty, badass speed. -Eleanor Roosevelt, 1936 |
02-05-2011, 04:13 PM | #6 |
Mrs. Bunny to you
02-05-2011, 04:17 PM | #7 |
PWA Relapse
Its possible that the springs are just settling in - turning a bit when you hit a bump until they get into a stable spot. But, if its something worse it'll be far worth the trip to have them check it out.
Should be ok to drive on it, but I wouldn't go dukes of hazard on it. - X
02-05-2011, 04:19 PM | #8 | |
Mrs. Bunny to you
02-05-2011, 04:22 PM | #9 |
Not sure what springs you went with but all of the hardware has specific torque settings. Make sure they have torqued everything to spec
Pfadt drop springs,
Pfadt sway bars Pfadt end links Pfadt rear tie rods Pfadt rear trailing arms Pfadt rear lower control arm reinforcement bracket Kooks Long tube headers and high flow cats Airaid Cold air intake Magnaflow catback exhaust Mti short throw shifter Jannetty tune |
02-05-2011, 04:33 PM | #10 |
probably the sway bar connections..how about some lowered pics?
02-05-2011, 04:41 PM | #11 |
I have no life
Drives: 06' Subaru STI, ex-Camaro V6 LLT Join Date: Apr 2010
What kind of bump btw? Speed bump? pot hole? Curb? That shouldn't cause any problems... mind letting us know brand of springs, and how much lower? I've heard people say while the springs are settling, it makes noises... o_o
Obviously better get it checked out incase, regardless.
02-05-2011, 04:56 PM | #12 | |
Mrs. Bunny to you
02-05-2011, 04:56 PM | #13 |
RIDING ON AIR
Drives: 2010 2LT/RS Summit White Join Date: Dec 2009
id say sway bar connectors. Mine did the same thing and I didnt tighten them down enough
--John--2010 Camaro 2LT/RS, Summit White Air Ride Suspension, BBK Longtube Headers, Hi-Flo cats, Doug Thorley catback exhaust, Elite Catch-Can, Airraid CAI, Trifecta tune, ZL1 front end with Phantom grille, ZL1 side skirts, MRR228 graphite wheels |
02-05-2011, 04:58 PM | #14 |
Mrs. Bunny to you
Similar Threads | ||||
Thread | Thread Starter | Forum | Replies | Last Post |
1 inch and 1.4 inch BMR Lowering Springs Now Available At APEX Motorsports!!!!!!!!!!! | Apex Motorsports | Suspension / Chassis / Brakes | 273 | 04-25-2016 05:17 PM |
Pfadt Race Engineering Lowering Springs Improve Looks And Performance. | Apex Motorsports | Suspension / Chassis / Brakes | 341 | 02-02-2014 11:52 AM |
BMR Lowering Springs - How It's Made | BMR Suspension | Suspension / Brakes / Chassis | 40 | 06-22-2010 10:32 AM |
