Old 02-03-2022, 05:56 PM   #15
CC2018SS1LE
Drives: 2018 Chevy Camaro ss 1LE
Originally Posted by juice3 View Post
Should be good all the way to cords.
I only run 2 deg negative in front and 1.5 negative in rear, I looked at tires, al outside of all tires are badly grained. I think I’m going to flip them on the over on the rim, maybe I’m not running enough camber. I drive the car on the streets, so I did not want to go more negative camber. Maybe I fried the outside lip, of the tires
They fell off 4 seconds a lap, it was a warm day 70-75 deg in Florida
Thanks for all your input
CC2018SS1LE is offline   Reply With Quote
Old 02-03-2022, 05:58 PM   #16
khcoaching
khcoaching's Avatar
Drives: 2021 1SS 1LE
Yep....way more camber I still think your pressure is way too low.
khcoaching is online now   Reply With Quote
Old 02-03-2022, 06:04 PM   #17
juice3
juice3's Avatar
Drives: 19 ZLE A10,17 SS 1LE, 16 C7R,CT5V
Not enough camber for these heavy pigs. Get it to 3+ front and 2+ rear, zero the toe in the front and a .03-.06 toe in in the rear.
juice3 is offline   Reply With Quote
Old 02-03-2022, 08:53 PM   #18
CC2018SS1LE
[QUOTE=juice3;11129306]Should be good all the way to cords.[/QUOTE
Old 02-05-2022, 08:15 AM   #19
CC2018SS1LE
I run 38lbs hot, because of my lack of neg camber
Old 02-05-2022, 08:21 AM   #20
CC2018SS1LE
I drive on the street, and to and from track, that is way too much neg camber for street
I think I’m going to go back to regular G3’s and run 305/30/19s up front
I never had a problem with the G3’s at 2deg neg camber
I’m going to flip tires, try to get 1 more track day out of them, thx for reply’s
Old 02-05-2022, 04:52 PM   #21
Junkyardspecial
Junkyardspecial's Avatar
Drives: 2018 ZL1 1LE
Excellent to the cords, could be something with the track or pressure issues you may be experiencing.
Subscribe to my Youtube channel!
https://www.youtube.com/c/Junkyardspecial
Will buy your GoodYear Supercar 3R Take offs!
Junkyardspecial is offline   Reply With Quote
Old 02-13-2022, 12:36 PM   #22
tomster
RedLine
tomster's Avatar
Drives: 2022 ZL1 1LE
Also great till they are down to cords.
Alignment specs
Camber: -3F & -2R
Toe 0F & .2R
As for air pressure. I found starting my first 20 Min section at 30psi and then blending off the air after my first time out to target 36psi hot works best. When I start at 26 like others I tend to drive too hard prior to the pressure coming up and the insides cord faster, than when I start at 30psi.... I found I get an entire extra track day just starting out at a higher pressure. Im sure I giving up a little grip on my first run but its worth it to me
2018 GMC 2500 "Blue" (Sold)
2018 ZL1 1LE Hyper Blue" (Sold)
2018 CTS-V "Black" (Sold)
2022 GMC 2500 "Blue"
2022 ZL1 1LE 6spd "Rapid Blue"
2023 ZL1 1LE Auto Rapid Blue (ordered)
tomster is offline   Reply With Quote
Old 07-22-2022, 09:57 AM   #23
Earlyapex1LE
I have mine set at the recommended Front negative camber of 2.75 and am getting uneven wear. Outside half of the tire is wearing much faster. Can you get over 3.0 negative on the stock ZLE suspension?
Thanks!
Earlyapex1LE is offline   Reply With Quote
Old 07-22-2022, 12:49 PM   #24
carguy55
carguy55's Avatar
Drives: 2018 1SS 1LE
With camber plates and SPL rear camber and toe rods I'm now at -3.5F, -2.5R, zero toe, and track wear is even across the tire finally. I also have a true square setup so I can rotate all 4 wheels.
Old 07-27-2022, 04:10 PM   #25
cdrptrks
cdrptrks's Avatar
Thanks!
Yes the ZLE has a front strut top mount that you can rotate for extra camber. You will need to get another alignment done since rotating this piece will change the toe which would negatively impact front tire wear if done by itself without another alignment. There are directions in the performance supplement.
Old 07-27-2022, 09:53 PM   #26
Earlyapex1LE
Thanks. I rotated the them and had it aligned to 2.75 neg in the front. I was just wondering if you can get more negative camber from the stock setup. One poster suggested camber plates. I am still getting uneven tire wear at 2.75 negative camber.
Old 07-28-2022, 09:44 AM   #27
cdrptrks
cdrptrks's Avatar
Yes there's more adjustment range available on your car then. The two strut knuckle nuts on each front corner need to be loosened and backed almost all of the way off then hammer on the bolt to release each hidden spline then push the top of the wheel/tire to max the camber and tighten them back up. Use the adjustment hole with the appropriate bolt from a hardware store to remove a bit of camber from one side before tightening if it doesn't initially match on both sides.
Old 07-28-2022, 09:57 AM   #28
cdrptrks
cdrptrks's Avatar
More details below and attached.
https://www.camaro6.com/forums/showp...87&postcount=8
