06-24-2018, 01:58 PM | #1 |
Drives: 2021 LT1 10 speed auto Join Date: May 2013
Had to post this
Had to share this , hope this post's correctly.
06-24-2018, 02:04 PM | #2 |
Drives: Camaro 50th anniversary edition Join Date: May 2017
Soleil
_____________________________________________ A car is fast enough, if you fear to unlock it in the morning." (Walter Roehrl) |
06-24-2018, 02:11 PM | #3 |
Smiles per gallon!
06-24-2018, 02:16 PM | #4 |
Drives: Grandad's C2 L89 Join Date: May 2017
Nice!
2018 ZL1 1LE sw/PDR
06-24-2018, 05:30 PM | #5 |
LOL...but the 6 gets a lot better mpg than my old pontiac big block ever thought about getting.
06-24-2018, 06:57 PM | #6 |
06-24-2018, 07:21 PM | #7 |
Drives: 2018 ZL1 Hyper Blue A10 Join Date: Jan 2018
06-24-2018, 07:47 PM | #8 |
I'm sure you've heard this before but you are wasting your money using 93 octane in a V6. The only advantage 93 gives you is it makes you feel like you're fueling a V8.
06-24-2018, 07:58 PM | #9 |
Opus13
Drives: 2017 Camaro 1SS, Black Join Date: Jul 2017
A Prius would never make me smile.
"My entire life in one sentence:
It didn't go as hoped, but that's okay" Opus ie. Berkeley Breathed. |
06-24-2018, 08:04 PM | #10 | |
The V6 has 11.5 to 1 comp ratio, the factory tune advance tables based on 87 octane is naturally very conservative. By running 93 octane, the timing tables utilized will include the max timing spec because no spark knock will be detected . Once the ECU utilizes the high octane timing tables, more power and better mileage. 93 Octane is super critical in the summer heat and if you want max power. |
Thread Tools | |
