10-21-2019, 07:32 PM | #1 |
Drives: 2018 RS Join Date: Sep 2018
Who here has successfully used transport mode for storage
Putting the Camaro in storage until Spring and I dont have electrical access. I have read threads about transport mode but cant find any threads about its successful use over the Winter. So, who here has used it for Winter storage and came back to a live battery in the Spring? Trying to decide between transport mode and disconnecting the battery.
10-21-2019, 07:49 PM | #2 |
Drives: 2017 HBM 2LT RS Convertible V6 A8 Join Date: Jan 2018
Aside from the hassle of disconnecting and reconnecting the battery, what is the advantage of leaving the battery connected? I don't think you lose any saved settings when disconnected, but even in transport mode there is a small parasitic drain. From what I've read here, your car may or may not have the same high or low drain as others, regardless of transport mode. Personally, I would give it a full charge before driving to storage, then disconnect if it's a month or more. Batteries do not like to lie dormant with a partial charge.
10-21-2019, 08:04 PM | #3 |
Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
It only takes a 1/4" ratchet with a 10mm socket and maybe 30 seconds to disconnect the battery. I would do that before I left the battery hooked up for months if I couldnt put a battery tender on it.
2017 Camaro SS 1LE - Procharger D1SC w/ Tial 2" BOV & Race intercooler / ARH full length catless headers / Alky meth injection system - 650rwhp on conservative tune SOLD |
10-21-2019, 08:26 PM | #4 |
Drives: 2018 2SS Camaro Join Date: Jul 2019
I just put my 2017 in storage, for the first time.
According to the manual...for extended storage... Disconnect the Negative terminal or use a trickle charger. Will see what happens in April 2020! |
10-21-2019, 08:45 PM | #5 |
Drives: 2017 Camaro SS Mosaic Black 6MT MRC Join Date: May 2016
I've been storing my car every year, change oil add proper amount of fuel stabilizer. Just disconnect negative battery cable,DON'T close trunk lid fully my 2017 SS doesn't have Trunk with a keyed lock, you'll end up climbing through the back seat to open it.
10-21-2019, 09:38 PM | #6 |
I just hooked up a battery tender to the battery post underneath the hood. My camaro fires up right away like I just put it away for the night. If you don’t want to use a tender, people that have used transport mode without any issues.
10-21-2019, 11:39 PM | #7 |
Dumb Ass Deluxe
Drives: A Tricked Out Mountain Bike Join Date: Jun 2019
You can try it. I'd think it would be easier and cheaper to pull a cable now than roll the dice and have to pull a battery later...
10-22-2019, 04:43 AM | #8 |
Drives: 2017 1SS Hyper Blue Join Date: Apr 2017
(oops, double post)
10-22-2019, 04:44 AM | #9 |
If you are going to disconnect the battery, take a couple more minutes and remove it from the car and bring it inside where it is warm and put a tender on it. Batteries don’t like sitting with no activity when it is cold.
