06-21-2017, 04:26 PM | #29 |
Drives: 2016 2SS Join Date: Nov 2011
Drag Pack Installed
I finally got everything I needed, mounted the tires and headed to the strip. I reduced my ET in the 1/8 by .3 of a sec in 2500 DA. Pretty happy with this set up. Tires hook solid at 18 psi.
Who Dares...Wins |
06-22-2017, 10:22 AM | #30 |
[COTW 1/6/14]
Drives: 2017 1LE Join Date: Mar 2012
im still waiting for someone to run 17s in the front for 6 pistons brembos.. I know there was pictures of it fitting.. but im still hesitating about it..
06-22-2017, 08:43 PM | #31 |
I will take one up to Classic next week and see if it will fit for ya.
Who Dares...Wins |
06-23-2017, 08:43 AM | #32 |
[COTW 1/6/14]
06-23-2017, 09:34 AM | #33 |
Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
If ultrazls1 shows up this weekend he said he'd let me test fit one. I'm sure they'll still clear, but highly doubt you'll be able to use stick on weights. Probably have to use the ones that go on the bead
"Spitfire" 427ci
2017 Red Hot 2SS// 6 Piston Brembos//Adrenaline Red Interior, Knee Pads//M6//MRC Afe Air Filter//BMR MM010 Motor Mounts, Safety Loop//Custom OTR Intake//Flex Fuel Kit//Gforce 3.5" Aluminum Driveshaft//GM 95mm TB//Katech Oil Pump, Piston Squirters//Kooks 1-7/8 LT//LT4 Fueling//Mighty Mouse Wild//Monster Clutch LT1-S Triple Disc//MSD 2-Step//Pray Performance Custom Spec Cam, Ported Holley Hi-Ram//Sikky 12" Shifter w OEM Knob Mod//Tick Level 1 Tr6060//Labor by Me//Tune By Pray Performance |
06-23-2017, 11:29 AM | #34 |
[COTW 1/6/14]
on my rear set I just put the weight on the back of the wheels actually
06-24-2017, 08:42 AM | #35 |
No I mean for the skinnies with the 6 piston brakes
"Spitfire" 427ci
07-06-2017, 08:48 AM | #36 |
[COTW 1/6/14]
did anyone try fitting 17s on the 6 piston brakes yet? still waiting before I pull the trigger on 18s
07-07-2017, 10:38 AM | #37 |
Unfortunately we didn't get to meet up and test fit them.
If anyone in near grand rapids has a set of skinnies and would like to meet up we could still try to test fit some.
"Spitfire" 427ci
07-12-2017, 09:28 AM | #38 |
[COTW 1/6/14]
yeah ive been holding off on getting skinnies because im not sure.. I know majority of the dealers said no.. but I guess ive seen some pictures around with 17s on.. 18s are just a pain for tire sizes lol
04-20-2018, 02:04 PM | #39 |
Drives: 2016 2ss Join Date: Mar 2012
04-20-2018, 06:19 PM | #40 |
If you haven't tried yet. 17s do fit. I made a thread because I couldn't remember what the name of this one was at the time
"Spitfire" 427ci
04-24-2018, 05:22 PM | #41 |
Drives: 2ss Join Date: Jan 2018
FWIW it took 4 guys, 1 ratchet strap, and an act of God for one of my front bias ply Hoosiers to pop the bead and mount. The other went to a local tire shop the next morning where it took two guys and a cheetah/air cannon and it was done in seconds.
I dig the rear slicks, I don't care much for the sketchy feeling on top end I am not used to yet. Lol |
Thread Tools | |
