05-13-2020, 10:22 PM | #1 |
Drives: 2010 Chevy Camaro 2SS Join Date: Mar 2020
Anyone Know What Swaybar This Is?
AFter purchasing a ZL1 sway bar and FE4 conversion I found out that the previous owner of my vehicle already mounted FE4 control arm and added an aftermarket adjustable control arm. I have no idea what sway bar this is though. Can anyone recognize this bar? It is grey in color with kind of metallic flakes
2010 2SS w/ Magnaflow 2.5 muffler, CAI Intake, Stainless Power LT headers, e85 Custom Tune, vararam power wedge, Vararam Ported TB, BMR rear sway bar, BC Racing coilovers.
05-13-2020, 10:39 PM | #2 |
SoCal Camaro5 Race Team
Drives: 2021 Shadow Grey Camaro 2SS 1LE Join Date: Mar 2010
Maybe Hotchkiss, they are grey. The pic does not look aftermarket. Definitely not fe4. That’s stock fe3 control arm and bar
05-13-2020, 10:49 PM | #3 |
The FE4 control arms can accept the FE3 endlinks. These even have the hole near the end of the control arm for the FE4 vertical links
05-13-2020, 11:21 PM | #4 |
05-14-2020, 08:40 AM | #5 |
Drives: 2015 Camaro Join Date: Aug 2018
Hotchkis are a low gloss black. Well, at least mine are.
05-14-2020, 12:01 PM | #6 |
Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
Might be old Pfadt. I think they used a metallic gray.
Sent from my SM-T837V using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
05-14-2020, 12:07 PM | #7 |
The tabs on the end of the bar look different though.
05-14-2020, 12:12 PM | #8 |
Drives: 2014 1SS/1LE Join Date: Nov 2015
BMR?
830 WHP 700 WTQ, Whipple 2.9 @ 13lbs Boost, Flex Fuel Tune by Blevins Tuning, LSA SBE, 3.5 GripTec, ATI LS3 Damper, AFR 260cc Mongoose, ARP Studs, Yella Terra Ultralites, Johnson 2110R, BTR PDS Stage 3, Melling 10355, Improved Racing Baffle, ID1050X, DSX Triple Fuel Pump, RotoFab CAI, NW 103mm TB, Stainless Works 1-7/8" LTH to 3" Speed Eng w/ X-pipe to NPP, Powermaster 9509 XS, Detroit Speed Motor Mounts, MGW, Monster LT1-S, ZL1 Calipers, DBA Rotors & Pads, Bilstein B6 Struts & Shocks, BMR 1.25" Drop Springs & Adj Rear Bar, Pegasus Solid Bushings, Z/28 Wheels, other misc parts.
05-14-2020, 12:13 PM | #9 |
That’s what I was thinking. I believe I have Pfadt lowering springs on my car too. I bought it used from a dealer. It’s hard to find out what these are without part numbers. Maybe the number is engraved somewhere small.
05-14-2020, 12:52 PM | #10 |
Could be right. I had Phadt years ago, fe4 like above. Color same
