03-03-2020, 07:15 AM | #1 |
Drives: 2019 ZL1 Join Date: Oct 2019
P275/40R17 on Weld 17x10's a direct fit on the Gen6 ZL1?
I was looking at the S77 Weld wheels in 17x10 on WeaponX's website and wanted to double check that with NT05Rs or MT ETS or ETR's in 275/40R17's would direct fit over rear OEM brakes and the MRC suspension.
I will be running 255/35R19 front tires on APEX 19x10 fronts so no worries about tire height differences, will only be 0.3 to 0.4 difference front to back. |
03-03-2020, 12:42 PM | #2 |
Drives: 2018 ZL1 Coupe NFG M6 Join Date: May 2017
They'll fit, much narrower than stock.
1989 Forumla 350 WS6 <- High School
2000 Trans Am Firehawk <- After High School 2017 Colorado Z71 <- Daily 2018 ZL1 M6 <- Not Daily |
03-03-2020, 02:23 PM | #3 |
Thats a really small tire compared to a 305/45 17, 2 inches shorter. It would put gear in the car which in theory should get it to 60 foot quicker! You have me rethinking my setup now! I only use mine at the track... puts the OEM stuff on for the street. The sidewall isnt as tall though... almost an inch difference.
2018 ZL1-NFG-A10
New Iron L8T 9.32 147MPH |
03-03-2020, 03:24 PM | #4 |
Thx. Also looking at 315/35R17's for the NT05R, same tire height but 11 wide vs 9.5. Would just need to get a 10.5 wide rim minimum, ideally a 17x11.
Anyone know what offsets on a 17x10.5 or 17x11 Weld wheel work without issues in the rear? |
03-03-2020, 05:32 PM | #5 |
Drives: 18 ZL1 nightfall grey A10 Join Date: Apr 2018
Probably stick with the 17x10 and put on a 305/45/17 ET street R.
03-03-2020, 06:39 PM | #6 |
03-03-2020, 08:54 PM | #7 |
03-03-2020, 09:19 PM | #8 |
Drives: 2017 ZL1 A10 Join Date: Nov 2009
Why are you running such small tires on the car?
03-04-2020, 11:46 AM | #9 |
03-04-2020, 12:43 PM | #10 |
03-04-2020, 02:23 PM | #11 |
03-04-2020, 03:22 PM | #12 |
If your running a Shorter tire on the rear then stock and trying to launch it in 1st its going to be hard to hook it. A10 has a lower 1st gear then the A8 and its low. Short side wall on a drag car just doesn't work that well. Some get away with it on an NA car but a SC car just hits the tire to hard with instant boost, NA cars don't do that. A 28" tall tire works the best on a SC car for sure and your going to be at 25.7.
03-04-2020, 06:14 PM | #13 |
Drives: 2018 ZL1 1LE Join Date: Nov 2019
Yea it doesn't make sense to run a tire that has an inch less sidewall height than stock. If you're worried about the gear then you can always change gears, but I promise you'd be better off running a taller/wider tire. The front side doesn't effect the speedo or your gearing btw.
03-05-2020, 06:47 AM | #14 | |
