03-08-2023, 11:24 AM | #15 |
Drives: 2022 SS 1LE Join Date: Apr 2022
I finished the install and it wasn't that bad. It looks a lot better then the stock setup under there. I'm now setup for when I get headers and install a supercharger. I also started it and test drove it.
1. Sound is more subdued on idle. I cold started it in tour mode by mistake, doh. So it wasn't real loud. I let it idle till normal water temp. I had water coming out by the clamps on both sides of the x-pipe. It did this for a minute or 2 and then stopped. I revved it and didn't see or hear any leaks. 2. I drove it for about 25 minutes and couldn't hear any leaks. The interior seems quieter. The cracks and pops are less, however it was 53 degrees out and that seems normal from what I remember from before with stock exhaust. It also "feels" like it had more power, but again that could be because of the cold temps. And apparently NC is deciding to be cold for the next month, even though it was 74 yesterday. Crazy weather. I'm glad I did this, because this has helped me decide that I do want long tube headers. So with Speed Engineering having them for 400, I'll be getting those within the year. Plus, I already have the connecting pipes from the x-pipe to the headers. Thanks to their mistake. I didn't put any sounds clips as I need better weather to compare it to, since I have records from before with warm weather. Hope this helps anyone l deciding to do this. |
03-08-2023, 02:32 PM | #16 | |
I'd like to hear any thoughts you have on this. |
03-08-2023, 09:26 PM | #17 | |
Drives: 17' Chevy Kamaro SS 6 speed Join Date: Mar 2022
Whats AFM? |
03-09-2023, 03:28 AM | #18 |
Drives: R.I.P. 2021 ZL1 & 2019 Rd Garn 2SS Join Date: Dec 2019
Do you have a manual or auto tranny? If you have a manual you won't have AFM but if you have an Auto it does. It stands for Active fuel Management. It has a second set of NPP actuators in the mid pipe I think before the stock crushed section. But a manual tranny car doesn't have it.
03-09-2023, 06:43 AM | #19 | |
Drives: 23 ZL1 A10 Rapid Blue Join Date: Aug 2020
03-09-2023, 09:52 AM | #20 | |
A8/A10's have AFM valves in the exhaust that partially close when 4cyl mode activates. M6 cars do not have this feature even though all LT1 engines have AFM/Dod lifters in the engine, but the feature is disabled in the tune on M6 cars. I am assuming on stock cars the AFM valve section isn't that restrictive similar to the crush section, but I would expect there to be gains on modded cars. Especially forced induction being that area necks down to about 2 1/4" not factoring the valve in the pipe. Imo it looks more restrictive than the crush section but nobody had ever really talked about it.
2016 NFG 1SS A8
03-09-2023, 10:35 PM | #21 | |
Drives: 2020 Camaro 2SS A10 Join Date: Jun 2018
2020 Camaro 2SS A10 | Rebuilt by: CBI Street Cars | 2" SE LT Headers | 3" SE X-Pipe | 3" MBRP Axle-Back | Pri & Sec Cat Deletes | K&N Typhoon CAI | LT2 Ported | 95mm ZR1 TB | DOD Delete | BTR Stage I Cam | ECM, TCM & E85 |Tuned by: Shane Hinds | Dyno: 510 rwhp 472 rwtq
03-10-2023, 09:09 AM | #22 | |
03-10-2023, 09:46 AM | #23 | |
Mine is manual. Yeh...I thought that was what AFM was but didn't know it had anything to do with the exhaust. |
03-10-2023, 01:55 PM | #24 |
Drives: 2020 Camaro 1SS M6, Ford Fiesta ST Join Date: Mar 2020
I'm interested to know how the sound of this Speed Engineering x pipe (that deletes the secondary cats) compares to the stock x pipe (that has secondary cats).
driftking123: You compared the sound of it to a modified factory x pipe that had the secondary cats already removed. So in this case, we're really just comparing the pipes themselves since both had no secondary cats. Correct? FlukeSS: When you installed yours were you replacing the factory x pipe that included the secondary cats? If so, how does it sound? Are you happy with it? How much louder? Or is it actually quieter? |
03-10-2023, 04:37 PM | #25 | |
The sound, I have a video of it. Warm and Cold starts. Cold Start Parking Garage Warm Start after exhaust installed Outside the car and inside the car sound at dragstrip
03-11-2023, 06:03 AM | #26 |
OK got it now. I didn't look at your signature to see you have long tubes, only at the link. Speed Engineering offers both styles of X-pipes, 1 for factory manifolds (as was originally posted) and 1 for long tube headers. It's tempting to buy these factory manifold style pipes from Speed Engineering. I already have an axleback that I haven't installed. It's fun to think about buying the Speed Engineering x-pipe to go with it, then no cutting on factory exhaust. If I ever got tired of it, then could just switch back to factory easier. I think this is the first time in a long time that an x-pipe like this has been offered. Maybe companies got scared to delete the secondary cats so that's why they quit offering. Last time I looked, all the other x-pipes designed to work with factory manifolds require cutting behind the secondary cats. These new Speed Engineering x-pipes are good news! If I order, I'm going to ask them why they have one listed for our cars and one for the Cadillac CTS-V under the same part number (SKU: 25-1064), except ours is $20 cheaper. Camaro https://speed-engineering.com/produc...16-6-2l-engine CTS-V https://speed-engineering.com/produc...19-6-2l-engine |
03-11-2023, 02:05 PM | #27 | |
Greenz28, yes it's the pipes. Now that I've put more miles on these pipes, they sound better. They are quieter at idle and start up, however are louder when on the gas. I also just added a ported TB and I'm definitely feeling more power. So I definitely recommend these pipes. They are better then just cutting of the second cat and welding pipes in place. Sound and power are much better. |
03-19-2023, 05:02 PM | #28 | |
Sounds great. This is my setup and a sound clip(cold start), but my phone camera's mic got blasted, so the revs don't sound good. |
