10-28-2015, 05:34 PM | #1 |
Rawr!
Drives: Giulia Quadrifoglio, C8 Stingray Join Date: Sep 2013
Tire pressure sensor reversed
So I just noticed my left and right tire sensors are reversed. How the heck did this happen?
I deflated my left rear tire as a test, and Camaro recognized the right tire as deflating. weird, right?
Current:
2023 Red Mist Corvette Stingray 2LT 2021 Trofeo White Alfa Romeo Giulia Quadrifoglio Retired: 2018 Garnet Red Camaro 2SS 2014 Crystal Red Camaro RS |
10-28-2015, 05:46 PM | #2 |
Drives: 2012 45th Anniversary Edition Join Date: Aug 2012
take to dealership and have the TPMS re-programmed, or whoever changed your tires last...
10-28-2015, 05:50 PM | #3 |
Drives: 2011 Camaro 2SS/RS Convertible and: Join Date: May 2014
Just switch the wheels/tires to the other side... though if you know it's reporting in reverse, then it really shouldn't matter other than if it bothers you.
Currently in my Garage: 2011 Camaro 2SS/RS Convertible | 1980 Corvette Stingray | 1981 Firebird | 1968 El Camino | 2007 Crown Vic Police Interceptor | 2001 Silverado | 2001 Blazer | 1965 Chevy C-10 | 2007 Harley Softail Custom | 2013 MX-5 in Copper Red Mica | 2000 Corvette Convertible | 2010 Corvette Grand Sport | 2006 Audi A3 Turbo | 2008 BMW 328i |
10-28-2015, 06:19 PM | #4 |
Drives: 2014 Red Hot LS3 Join Date: Oct 2014
TPMS dyslexia
10-28-2015, 06:20 PM | #5 |
10-28-2015, 06:33 PM | #6 |
Drives: 2010 1SS Join Date: Aug 2015
Maybe it didn't have enough catch cans and got confused..
2010 1SS LS3, Black, 235/250, .621/.615, 114 + 4, Kooks Stepped Headers, 3.91's, Bo White PTB, Flowmaster Mufflers, Cold Air Industries CAI, Apex Scoop & Windshield Washer Relocate, SLP Wheels, Skip Shift Eliminate, Barton Flat Stick, OEM HID/Halos, Dyno Tuned by ECS
10-28-2015, 06:38 PM | #7 |
10-29-2015, 04:57 AM | #8 |
Probably came from a tire rotation/change, if you've had that done. I cross-rotate my tires at every oil change (about 5K) and just have to keep it in mind that every other 5K miles the reading for right and left side are actually reversed. No big deal.
2013 1SS/RS Coupe L99, Stainless Power Works LT Headers, SCT X4 Custom Tune from RDP, CAI Inc. Air Intake w/ Apex Scoop, VMAX CNC Ported Throttle Body, Solo Axle-Back Exhaust w/ J-pipes, Apex Catch Can, Husky Splash Guards, Heritage Grille, 3D Carbon Rear Spoiler, Oracle Chrome Turn Signal Bulbs, GM Reverse Light Trim Billets, Gorilla Black Locking Lugs, Emblem Pros Retro SS Badges/Custom Retro SS Kickplates/Under-hood Bowtie, 35% window Tint, Nitto Motivo Tires (6-8-18)
10-29-2015, 06:46 AM | #9 |
BUMBL Z
Just relearn the sensors, it's the easiest thing in the world.
From the manual: The TPMS sensors can also be matched to each tire/wheel position by increasing or decreasing the tire’s air pressure. If increasing the tire’s air pressure, do not exceed the maximum inflation pressure indicated on the tire’s sidewall. To decrease the tire’s air-pressure use the pointed end of the valve cap, a pencil-style air pressure gage, or a key. You have two minutes to match the first tire/wheel position, and five minutes overall, to match all four tire/wheel positions. If it takes longer than two minutes, to match the first tire and wheel, or more than five minutes to match all four tire and wheel positions, the matching process stops and you need to start over. The TPMS matching process is outlined below: 1. Set the parking brake. 2. Turn the ignition switch to ON/RUN with the engine off. 3. Go to the TPM vehicle information screen on the DIC. See Driver Information Center (DIC) on page 4-27. Press set to relearn the sensors. The horn sounds twice to signal the receiver is in relearn mode and Tire Learning Active message displays on the DIC screen. 4. Start with the driver side front tire. 5. Remove the valve cap from the valve stem. Activate the TPMS sensor by increasing or decreasing the tire’s air pressure for 10 seconds, or until a horn chirp sounds. The horn chirp, which can take up to 30 seconds to sound, confirms that the TPMS sensor identification code has been matched to this tire position. 6. Proceed to the passenger side front tire, and repeat the procedure in Step 5. 7. Proceed to the passenger side rear tire, and repeat the procedure in Step 5. 8. Proceed to the driver side rear tire, and repeat the procedure in Step 5. 9. After hearing the confirming horn chirp, for the driver side rear tire, the horn sounds two more times to signal the tire learning mode is no longer active. Turn the ignition switch to LOCK/OFF. 10. Set all four tires to the recommended air pressure level as indicated on the tire and loading information label. 11. Put the valve caps back on the valve stems.
Current: 2015 ZL1 M6, Rotofab Intake, LS3 throttle body, 2.55 Upper/9.17 Lower w/ Idler Relocation, DMS Reinforced Brick, ID1050X, 1 7/8" Headers, ProSpeed HX/Reservoir, DSX Aux Pump/Flex Fuel Sensor, E85, McLeod RXT, BMR 1" Drop, Tuned by Pat G
Past: 2010 2SS, some bolt ons, 415rwhp/400rwtq |
10-29-2015, 07:41 AM | #10 |
Your tires got rotated and the toms never got calibrated after.
Modifications
GM Dark Tail Lights / 3rd Brake Light & Reflectors | LED Reverse Lights | Diode Dynamics Side Markers | Borla "ATAK" Cat Back Exhaust |
10-29-2015, 07:44 AM | #11 |
Drives: 2015 Silver Camaro 1lt RS M6 Join Date: Apr 2015
Same thing happened with mine. Took it to dealer and 5 min later I was good to go.
Cold air induction cai, ported throttle body, Vitesse Throttle Control, Oracle Ghosted LED side markers
10-29-2015, 07:53 AM | #12 | |
Depending on his year of camaro, you can't do this. Sent from my iPhone using Tapatalk
Modifications
10-29-2015, 08:21 AM | #13 |
Drives: 2022 2SS 1LE Join Date: May 2014
This
8/27:Ordered 2022 Vivid Orange Metallic 2SS1LE
11/09:Built 12/4:Took it home |
10-29-2015, 02:11 PM | #14 |
BUMBL Z
Really? I thought it was as long as you had the sensors that you could do this from the DIC. I have a 2010 2ss, if that makes any difference
