07-28-2021, 05:10 PM | #57 |
2020 Shadow Gray 2SS
If you are using the rubber blocks, they arrive with a thin coat of oil on them, I would thoroughly clear then off with some Isopropyl to give them more stick and less slip...
2020 SGM 2SS - A10, NPP, MRC, Red Calipers, Black Camaro Fender Badge, Footwell Lighting
Added after delivery: - GMP CAI, GMP Black Strut Tower Brace, MRR017 1LE Wheels, SS Armrest, Black Fuel Door, Stainless Sport Pedals, SS Wheel Caps, Black Lugs/Locks, GM Splash Guards, DD Smoked LED Markers, Smoked Rear Reflectors, Mishimoto Catch Can, Xpel PPF - Full Front, SunTek 35% Tint, CeramicPro coating, RST Stainless Brake Lines, Castrol SRF, MSD Super Conductor Wires Left: My "fun" ride. Right: My "work" ride: a Gulfstream G600. One's top speed is 180 Mph, the other, 620 Mph... |
07-28-2021, 07:55 PM | #58 |
Drives: 2018 Cadillac CTS-V Join Date: Jan 2020
Make sure to check your fittings as soon as you get your order. They make you buy both male/female fittings for $80 if you're out of warranty.
08-01-2021, 07:47 PM | #59 |
Drives: 2023 ZL1 M6 Join Date: Sep 2018
I had the 5000 slt and they were kinda short. I sold them and bought the 6000XLT and they work great. A lot heavier to move around, but go wheel to wheel.
2024 Riverside Blue ZL1 M6
Magnuson 2650R, NW 103, Roto Fab Big Gulp, Jet Hot Coated ARH 2 inch LT's, Stainless Works NPP, Too High PSI Billet Valve Covers, Mighty Mouse Wild CC Signature Forged 20x10.5/20x11.5, 295/30-315/30, BMR springs, BMR Cradle lockout, AAD Billet Control/Trailing arms 2023 Vivid Orange ZL1 M6 - sold 2019 Riverside Blue ZL1 A10 - sold |
08-02-2021, 02:36 AM | #60 |
Drives: Camaro 1LE Join Date: May 2018
08-02-2021, 12:04 PM | #61 |
Limitless Imagination
Drives: 2018 ZL1 & 2022 Hayabusa Join Date: Dec 2016
If anyone is curious, he gave a report on why QJ lifting pads failed. I commented on original video asking if he used the tall or short pads, he replied with short ones. In this video that apparently wasn't the case, he was indeed on the tall ones.
TLDR: He said it was due to using taller pads in conjunction with the magnetic jack pad. https://youtu.be/x1bwojoXwP4?t=473
2018 Camaro ZL1 - Black
- OEM Options: A10, Exposed Carbon, PVR, Nav, No Sunroof - Lightly Tinted GM Dark Tails, DD Side Markers, Morimoto 5000k, 100% LED - RotoFab Dry, Forgestar CF5V (ZLE Spec), Eibach Pro, AeroForce Interceptor, GT4 Tow Hook - Carbon Fiber (Satin): Radio, Shifter, Steering Wheel Controls, Shifter Top, AC Vents, Side Mirrors & Shark Fin 2022 Suzuki Hayabusa - Brilliant White Pearl & Shocker Yellow Wheels - +4 Arm, 240 OEM Wheel, Brock's CT (Ti) Exhaust, 1.25" drop, etc... |
12-17-2021, 07:23 PM | #62 |
Drives: 2018 ZL1 Nightfall Grey Vert Join Date: Dec 2020
Just got a Quickjack 5000TLX. All the quickconnect fittings leak! No matter how many times I try to seal them.
So frustrating when you spend this much and end up with useless junk. Any ideas how to fix it? This sucks. |
12-17-2021, 09:57 PM | #63 | |
Drives: 2023 CT5 Blackwing Join Date: Sep 2016
Did you tape the fittings? I've never had fittings leak when taped.
2017 HBM SS 1LE
Sold 2023 Wave Metallic CT5-V Blackwing M6 |
12-17-2021, 10:04 PM | #64 |
Instructions said not to use tape because it could contaminate the system and can lead to all sorts of trouble.
Used their included thread sealant as directed (multiple times) with no success. All I got was puddles of trans fluid all over the garage. |
12-17-2021, 11:47 PM | #65 |
You can use tape instead of the sealent if you'd like. It says so in the latest manual. I taped mine and not a drop going on 3 years.
12-18-2021, 02:44 AM | #66 | |||
12-18-2021, 06:53 AM | #67 |
the sealant they give is useless goo...use teflon tape as specified above. Don't put tape over the last thread (closest to the opening) and wrap it in the correct direction.
12-19-2021, 10:56 AM | #68 |
Drives: 2021 LT1 Join Date: Aug 2020
I bought mine 1 year ago, I have the bottle o' goo, and I've had zero leaking fittings.
Now I was missing one Schrader valve and it took them way too long to send it to me, but that's a different story. |
