Old 09-22-2018, 06:55 PM   #1
XXX ZL1
XXX ZL1's Avatar
Drives: 2023 ZL1 M6
How much power on stock fuel system?
Plans are ARH 2 inch long tubes, rotofab, and magnuson 2300. Plans are to proceed next year with cam and heads, but wanting to keep it simple till new smell wears off. What kind of power is safe through A10 without fuel mods?
XXX ZL1 is offline   Reply With Quote
Old 09-22-2018, 07:52 PM   #2
LiqTenExp
LiqTenExp's Avatar
Drives: 2017 ZL1
I wound up at 708whp on mustang from 520 with M6 car on mustang dyno. I have ported stock heads, 103mm tb, and cam but 1-7/8" ARH headers with rotofab and magnuson 2300. Low side fuel started to give way once we hit 700 whp but is still safe there. Looked like we could have reached 740 but that would have really been pushing low side to below 50psi likely.
Old 09-22-2018, 08:17 PM   #3
XXX ZL1
XXX ZL1's Avatar
Drives: 2023 ZL1 M6
Thats 750-775 on a dynojet. How are IATs with maggy?
Old 09-22-2018, 08:42 PM   #4
Drsagacity
Drsagacity's Avatar
I added the voltage booster and see 70psi all the way to redline. Everything looks good to about 740whp and will be upping the boost by a few more pounds next week.
776whp/745wtq (12psi)
2018 Corvette Z06 vert- Black
To be tuned by JRE Racing
TBD performance
Old 09-22-2018, 08:44 PM   #5
XXX ZL1
XXX ZL1's Avatar
Drives: 2023 ZL1 M6
Both you guys have a cam for high side fueling. Without cam where does it run out?
Old 09-22-2018, 08:46 PM   #6
Blackdevil77
Blackdevil77's Avatar
Drives: 2008 Pontiac G8 GT, Shelby GT500
Based on what I've seen here, it seems to be about ~650ish rwhp, but I'm curious to see if anybody made more without taking apart the engine. Only exception seems to be a blower swap to a procharger type unit.
Blackdevil77 is offline   Reply With Quote
Old 09-22-2018, 10:20 PM   #7
WEAPON-X
WEAPON-X's Avatar
Drives: ZL1 ATS-V CTS-V C7Z Range Sport SC
With our Boost Freeze Chiller, you can pack more timing into the tune. We saw 4* more timing, ZERO knock, 60ish whp more if I recall, 35* water temps, 10% less boost due to the freezing cold air going into the engine!
We made 685whp with only 12 psi on Intimidator's setup in testing and his only mods were:
  • WEAPON-X Stage 1 Intake
  • WEAPON-X 15% upper pulley
  • NX Lid
  • WEAPON-X Boost Freeze Chiller
  • WEAPON-X Ported Supercharger
  • 103mm Nick Williams TB
  • 2" Kooks Headers
  • Flow Master Mufflers (no power just sound)
We can run up to a 23% pulley combo before we see rail pressure drop on 93 octane, so I REALLLLLLLLLY want to get him back in for a lower pulley and see where it ends up. I put the over/under at 720!
The best part about our chiller is the fact that it makes your power repeatable and you can not only make MORE power, but you can also drop your temps right back down after a run within minutes vs. an hour!!!
Detailed info/logs
https://weaponxmotorsports.com/blogs...th-a-15-pulley
WEAPON-X is offline   Reply With Quote
Old 09-22-2018, 10:23 PM   #8
WEAPON-X
WEAPON-X's Avatar
Usually in the 750whp range give or take, but the low side drastically helps the high side. The pump will cavitate if it doesn't have a constant feed supply and that is when you start to see knock in the logs regardless if AFR looks "OK"
I put this together for you guys earlier this year in case it helps:
https://www.camaro6.com/forums/showthread.php?t=518331
Old 09-23-2018, 12:00 AM   #9
XXX ZL1
XXX ZL1's Avatar
Drives: 2023 ZL1 M6
So if a low side enhancement is added, the high side will support 750 rwhp? Thats a good start on a build for sure. I appreciate you posting!
Old 09-23-2018, 06:15 PM   #10
Markoz28
Drives: 18 ZL1 nightfall grey A10
How far can you push the LT4 with Mag 2300 and low side fuel? No cam or any other fuel mods.
Markoz28 is offline   Reply With Quote
Old 11-25-2018, 10:55 PM   #11
GunMetalGrey
GunMetalGrey's Avatar
Drives: Track prepped 2018 Camaro ZL1 (a10)
What about on 91 octane?
2018 ZL1; Mag 2650 and 2 inch LT Headers , every SPL suspension upgrade, MCS 2 way coilovers, sway bars, square SC3R 325's all the way around, and multiple brake cooling upgrades
GunMetalGrey is offline   Reply With Quote
Old 11-25-2018, 10:56 PM   #12
GunMetalGrey
X2
Old 11-26-2018, 06:30 PM   #13
WEAPON-X
WEAPON-X's Avatar
with a cam yes
you get a little more airflow with less boost but you still need the fuel, so you're still around 650-670whp
unfortunately less due to lack of timing
