Old 02-03-2021, 09:19 PM   #15
FarmerFran
FarmerFran's Avatar
Actually one of the things I like about my RAM is starting it up from my lab and walking out to a cool vehicle in the summer or warm vehicle in the winter. With Smartass phone start.
But I would still rather the RAM be a manual!
But I suppose it will be electric soon either way
Old 02-03-2021, 09:36 PM   #16
Petrol Head
Drives: Fast if no one's looking
Lay a brick on the brake pedal after you exit
Right idea but the brake lights would stay on till you either started the car or the battery died.
The signal switch tells the ECM the pedal is pressed then the ECM enables the engine start sequence to be completed and sends 5v to the relay to 12v to turn on the brake lights.
Petrol Head is offline   Reply With Quote
Old 02-03-2021, 09:41 PM   #17
Petrol Head
I’d go for a 2018 low mileage Ram 2500 Cummins 6 speed if I needed/wanted a pickup.
Or a 2007 Chevy Silverado/GMC Sierra HD2500 8.1 liter gas with the 6 speed.
Old 02-03-2021, 09:59 PM   #18
FarmerFran
FarmerFran's Avatar
Do not need that much truck at the moment
I have me a CreamPuff Truck
Old 02-03-2021, 10:11 PM   #19
gtfoxy
Drives: '21 Wild Cherry ZL1
Cannot help there, the man pedal prevents my car from having remote start from the factory.
I jest
Anyone else?
It’s all good.
I can row my own quite adequately, thank you, but man this 10spd is smooth as silk.
Old 02-03-2021, 10:12 PM   #20
FarmerFran
FarmerFran's Avatar
Originally Posted by gtfoxy View Post
Anyone else?
It’s all good.
And electric is that much smoother <--- says that to every automagic owner
again - I jest
Old 02-04-2021, 12:23 AM   #21
gtfoxy
again - I jest
A twin longitudinal 5.3L, V16, quad turbo, non transmission would be even smoother, & cooler.
I don’t jest.
Old 02-04-2021, 04:20 AM   #22
Petrol Head
Oh I wouldn’t either - it’s just that they’re the last ones you can row your own gears with and that’s the only reason I’d buy them
Old 02-04-2021, 06:45 AM   #23
LT4Greg
LT4Greg's Avatar
Drives: 2017 Camaro ZL1 Coupe
My 2005 Silverado 1500 regular cab is a 4.8 liter 5 speed manual combo! It was the last year for the V8 5 speed in the Silverado. The 2006 Classic had a V6 with a 5 speed. I’m keeping mine.
Old 02-04-2021, 06:47 AM   #24
ember1205
Hot Camaro
ember1205's Avatar
If your base trim is a 2SS (I don’t know if ZL1s are all 2SS or can be 1SS that’s why I ask) there is a setting in the climate control sub-menu settings where you can adjust the fan speed in auto mode
If I'm not mistaken, that setting is to control the max speed that the fan will run in Auto mode. My climate control is always on Auto and the fan generally never spins up to full high because it doesn't need to.
Unless you live in AZ and have the temp set to "Min", it shouldn't run at full blast like that.
OP - Have you ever just left it alone for a few minutes to see if it starts ticking down once the temp starts normalizing (assuming you're using Auto mode)?
Old 02-04-2021, 07:02 AM   #25
gtfoxy
That thing needs a turbo!
Old 02-04-2021, 07:21 AM   #26
FarmerFran
FarmerFran's Avatar
2 of them!
Old 02-04-2021, 07:48 AM   #27
Petrol Head
The manual was offered until 2007 in the HD2500 series classic - if I find one with the 8100 and 6 speed combo in good shape that hasn't been roached out for a decent price I may get it just to get one. The last true big-block production V8 GM made.
https://www.cargurus.com/Cars/2007-C...Overview-c8239
Old 02-04-2021, 09:34 AM   #28
Mister Will
Mister Will's Avatar
Drives: 2021 Camaro ZL1 A10
Yes, for a few minutes. The question is was it long enough?
Mister Will is offline   Reply With Quote
