01-09-2018, 03:05 PM | #1 |
Drives: 2017 Camaro SS 1LE (F1A-94 FBO H/C) Join Date: Jun 2017
Idle surging after cam install
So I recently cammed my 17 SS 1LE and have been noticing quite a few codes and issues my car has been having. But nonetheless the codes are all gone now as my tuner and I have been working endlessly on getting the car to 100%.
My tuner has done a cam install as well as much more on 2016 camaros before and has tuned my car the same as he has done those but for some reason my 2017 just isn’t liking it. Just got the car back a day or so ago and at first the idle was spot on perfect at 850rpm, but now that I am driving it more, especially on cold starts it idles below it which is caused by some pretty decent surging. It goes and comes but I would say 90% of the time the idle is surging (meaning bouncing up and down). Obviously the car appears to need some more tuning done to take that away and we are working towards that but I’d like to go out my way to see if anyone of you all can provide me some help. I am driving the car a lot more now to see if it just goes away eventually. But is that the case? Does the surging go away? Anyone else experience this? Would be GREATLY appreciated on any feedback in resolving this as it would 100% clean the idle up and make it sound as mean as it should be sounding. Anything I can send my tuners way that we can try will be very helpful. I have a video or two after my cam install you all can hear if interested to see the issue, videos can be seen if searching MP3BOOSTED. Either way the car is just surging at idle and would like to clean that up.
Performance Mods: F1A-94, DSX Flex Fuel Kit, MSD Spark Plug Wires, KOOK 2" off road headers, MBRP Race catback exhaust, Pray Performance Custom Boost Cam, Rocker Arm Trunion Upgrade Kit, 7.850" Hardened Chromemoly Length Pushrods and Johnson Racing 2110R Lifters, TSP CNC'd Heads, Ported MSD intake manifold, 103mm Katech Throttle body, Forged Pistons/Rods, RPM Meth kit, DSX Aux Fuel system, AEM Failsafe and banks gauge, LT4 HPFP, LT4 injectors, BMR motor mounts, Hurst Short Throw, Manley SS exhaust valves
Videos of my car? Check here: https://www.youtube.com/channel/UCNi...Qy1OL4NVGlPogw |
01-09-2018, 06:18 PM | #2 |
Drives: 2017 ZL1 A10 Join Date: Jul 2014
The only advice you're going to get is to take it back to the tuner or find a new one. Check for vacuum leaks that's about all you can do.
01-09-2018, 07:16 PM | #3 |
Yeah I figured, we did check for any vacuum leaks and all is well
01-09-2018, 08:47 PM | #4 | |
Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
I also installed a air fuel gage just to make sure I am at correct settings always. That was a big thing with myself. Not sure if this your problem but my surging disappeared after a few adjustments or it was the ECU that took that long to learn. I have a 2016 and no problem surging now, my friend has a 2017 and sounds exactly what you have.
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
01-09-2018, 09:11 PM | #5 |
Drives: 2016 camaro ss Join Date: Oct 2010
Maybe it throttle is letting in too much air at idle. Honestly I couldn't tell you with so little info. A good tuner could fix this such as EFI Tuning. Big big cams can idle rock solid at that rpm though so it's not too low of an rpm.
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS RIP : 2002 WS6 Black, A4, 355rwhp |
01-10-2018, 01:46 AM | #6 | |
01-10-2018, 01:49 AM | #7 |
Yeah it’s true, I do stand by it being just a little to much air or some fine tuning adjustments needed. My dads GTO and brothers trans am are spot on with my tuner, they are the reason why I went to this guy, the owner / tuner also has a camaro ss as well as I searched around my area who has tuned a lot of 6 gen camaros and he was the only one so far has gotten very good feedback on them. So I shall see. I’m going to adjust the cold air intake a bit, clean it out while I’m at it and see if that does the trick.
01-10-2018, 04:03 AM | #8 | |
CAMSHAFT POSITION SENSOR - GM (12623093) SHOP FOR RELATED PARTS IN POWERTRAIN CONTROL List Price: $21.44 You Save: $9.00 (42% off) Sale Price: $12.44 ADD TO CART
01-10-2018, 06:36 AM | #9 |
Drives: 2017 SS 1LE Mosiac Black Join Date: Nov 2016
One problem I have and understand it is fairly common in cammed M6 6gens, is that the rpm will drop below idle speed for a second or two before returning to idle speed when disengaging the transmission when stopping. I do not believe there is a fix yet for this problem, albeit an intermittent one.
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ Last edited by DFW1LE; 01-10-2018 at 07:48 AM. |
01-10-2018, 07:46 AM | #10 | |
SABIO
01-10-2018, 10:39 AM | #11 | |
Drives: 2018 ZL1 Join Date: Oct 2011
2018 ZL1…Many mods to come
01-10-2018, 11:15 AM | #12 |
5 degrees of overlap should not be hard to tune, but the 2017-18 ECM are more finicky. Probably some anomaly in the tune that the tuner might of overlooked. Also it's not uncommon to make a tune change and whatever issue you have temporarily goes away all to return. Sometimes it can take upwards of 10 different tunes to get a cam car fully dialed in. I would take the car back and let tuner go back through it.
2016 NFG 1SS A8
01-10-2018, 01:37 PM | #13 |
Yes. I believe there is something within HP Tuners that has yet to be unlocked before this small issue can be resolved.
Frankenstein Engineering Dynamics Stage 1 H/C/E85 536HP/488TQ |
01-15-2018, 02:40 AM | #14 |
its your tune take it back to the tuner. its common. I forget what needs to be changed. I had the same problem and tuner fixed it no problem on my cammed 5th gen.
