03-29-2022, 11:15 AM | #1 |
Drives: 2020 Camaro ZL1 Join Date: Oct 2020
Thoughts on wrapping zl1
I don't mean the clear PPF that we've all heard about, I'm talking about a full color change. I don't plan on doing it myself, I'll leave it up to the professionals but wanted to get everyone's thoughts first. If you have done it post it up, and post your thoughts good/bad/otherwise on wrapping your car.
2020 ZL1 A10 Shadow Gray Metallic
Magnuson Magnum DI TVS2650R| Mamo Throttle Body V2| RotoFab Intake| Borla S-Type Catback Exhaust| TCM Tune| Tune| Eibach Pro| BMR Rear Cradle Lockout| PPF| Ceramic| BCForged HCS21 |
03-29-2022, 12:48 PM | #2 |
Drives: Chevy Camaro ZLE Join Date: Mar 2022
I have wrapped a few cars.. a couple of things to consider:
-Who you have wrap the car makes a big difference, dont go for the cheapest price or you will be disappointed when you remove it and see cut marks all over your car -Be realistic with how long it will last. Most wrap jobs stay looking good for 2-3 years max -It will be expensive (4-5k) -If it scratches, you will need the panel re wrapped -If you are keeping the car outdoors, the wrap will last about half of the time it should |
03-29-2022, 01:25 PM | #3 |
Drives: 2003 Monte Carlo SS SLP, 2022 ZL1 Join Date: Aug 2021
How does it affect the paint under it? Suffice to say it will not look good after removal?
03-29-2022, 01:58 PM | #4 |
My ZL1 is a garage queen, so I would expect that the wrap will last longer than they predict. But to answer your question, I have watched the same place that I would have do my wrap, remove one and the paint underneith looks flawless. They said the only time they have problems is when the car had either been in a wreck that the owner was unaware of and had a bad paint "redo", the wrap may peel the bad paint job off when being removed. If it's stock paint there should be 0 issues with removal.
03-29-2022, 02:03 PM | #5 |
From speaking with the shop, it has 0 affect on the paint underneath it. Unless there is some unknown "paint repair" that was done in the past that wasn't good there should be no issues.
03-29-2022, 02:10 PM | #6 | |
Drives: 2019 ZL1 Join Date: Mar 2019
Expensive always doesn't mean better.... You can buy good vinyl and a shitty install or vice versa. You don't need a razor to cut vinyl btw. Knifeless finish line can be used on most of the car. Good wrap lasts much longer then 2-3 years. Also, there's self healing wrap, I have it on my car scratches are a thing of the past.
LME 377 LT4 Short Block | Magnuson 2650 80mm upper w/13% lower (9.06) | DSX Lid & Valve Covers | CSP Custom Cam w/32% fuel lobe | CID Heads | NW 103mm TB | Roto Fab Big Gulp | CSP 2" Headers w/Green GESI Gen 2 Cats | Borla 3" Full Cat Back w/ S-Type| Mighty Mouse Wild Catch Can| Custom Holley Low side Fuel system| TooHigh PSI Port Injection w/Holley Controller | Forced Inductions Interchiller w/2 gallon fender tank | TK Performance built 10L90 |
03-29-2022, 02:29 PM | #7 | |
03-29-2022, 03:37 PM | #8 | |
When heated, or just heat from sun many imperfections vanish.
03-29-2022, 07:44 PM | #9 | |
03-29-2022, 09:37 PM | #10 | |
I agree that expensive doesn’t always mean better, I always recommend going to a shop in person and seeing them wrap a car, the tools used and the cleanliness of their shop before signing up for anything. A good shop will be happy to take you on a tour. Every time I have removed a quality film from a car with no paintwork it has come off and the paint underneath was exactly as it was before I wrapped it. |
03-29-2022, 10:17 PM | #11 |
Drives: 2022 ZL1 Join Date: Feb 2022
Not sure this will help but Ill add my story for consideration. I have always been against ppf ( I know that is not wrap but its a film and my story would be same for ppf or wrap ) for several reasons. One its costly and any ding or what ever I would get without it can be fixed for a fraction of the cost among other things. Well I got a new supra and against my better judgement my wife insisted we get ppf on the hood and front end. I argued against it but lost. So I paid someone 1200 to do the front end and hood. On way home car in front of me kicked up a rock and it punctured and dented the hood( Im sorry at 80 miles and hour with a sizable rock coming dead bang in the opposite direction not even ppf is gonna stop it). so almost immediately 1200 bucks out the window. The issue is now with the ppf punctured only way to fix is to completely remove and reinstall which aint happening as i just dropped 1200 bucks not 10 mins before this happened. And to top it off with the ppf on the car the dent cant be fixed. SO I have now been living with a torn ppf and dent on my hood for the last year because there was no way i was ripping off 1200 worth of ppf. Anyway never again with films or ppf. Sure they look great but when something does happen they are gonna cost your azz to fix on top of the cost to install. If I had not had PPf on the car I could have had the dent and paint chip fixed for less then 100 bucks instead im living with a dented and torn 1200 ppf that to replace would cost another 1200 plus the dent repair. Not worth it.
03-29-2022, 11:12 PM | #12 |
Thank you Al Oppenheiser!
What will really bake your noodle is when you realize that if you hadn't done the PPF you wouldn't have been driving home at that time on that road when the rock was kicked up.
03-29-2022, 11:14 PM | #13 |
Drives: '19 M2C / '19 ZL1 Join Date: Aug 2021
i did my corvette and would do it again
03-30-2022, 05:01 PM | #14 | |
Drives: 2021 Camaro ZL1 A10 Join Date: Nov 2018
2021 Camaro ZL1 A10
2022 GR Supra 3.0 Past: 2018 Mustang GT Premium w/ PP1, MR, and A10 2007 MazdaSpeed3 1995 Pontiac Trans Am 1987 Camaro Z28 |
