Old 03-28-2022, 10:06 AM   #1
SATINSTEEL1LE
Drives: 21 ZL1
Brand new stock/untuned ZL1 LTFT's very negative, normal?
Im trying to find out if I should be concerned with my new 21 ZL1 I just got. The Long term fuel trims are very negative which means the car is trying to undo a very rich condition that I assume the stock tune is calling for?? I dont have a wideband installed, so the log I have has limited info. Is this normal for a stock ZL1 a10??
SATINSTEEL1LE is offline   Reply With Quote
Old 03-28-2022, 12:13 PM   #2
wnta1ss
Drives: 2017 Camaro 1SS
Seems weird. There was just a thread where a guy picked up his new ZL1 and it was getting VERY BAD mpg. He ended up unplugging the battery for a while to 'reset' the car. After he hooked it back up and drove some more, he said it acted MUCH better?
Old 03-28-2022, 05:35 PM   #3
SATINSTEEL1LE
Drives: 21 ZL1
Yeah I was the one that told him to do that. Lol. I’ve done that a few times and my gas mileage is completely fine. Im looking at fuel trims. This is probably the wrong forum to ask. I’ll take this to the HPTuners forums.
Old 03-28-2022, 08:09 PM   #4
KingLT1
KingLT1's Avatar
Drives: 2016 1SS NFG A8
-11% is not that rich. Very rich would be the point where the ECM can not correct. It's still able to correct afr to maintain stoich. I do agree it's odd that it's showing -11%. Most stock tunes are around 0 to +5%. Try resetting the fuel trims and see what happens.
2016 NFG 1SS A8
Options-2SS Leather/NPP
Old 03-30-2022, 07:53 PM   #5
JANNETTYRACING
JANNETTYRACING's Avatar
I would expect to see this if you are using Non Ethanol fuels.
Ted.
www.jannettyracing.com
Celebrating 37 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705
email tedj@jannettyracing.com
Old 03-30-2022, 09:38 PM   #6
SATINSTEEL1LE
Drives: 21 ZL1
Ted.
Im not. Im using standard 93 from Shell.
Old 05-08-2022, 07:50 AM   #7
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
That isn't unusual at all
Megahurtz is online now   Reply With Quote
