Old 09-20-2019, 10:28 PM   #1
ZLBlue
ZLBlue's Avatar
Drives: 18' RS
Concern on rubbing from BMR Lowering Springs
I'm interested in BMR's lowering springs for Camaros. I have put the OEM ZL1 1LE wheels on my A10, which I had the front struts shaved slightly to fit in the front 305s.
Since I'm on Mag ride on much wider wheels, I'm concerned about rubbing if I lower the car. The tires are already really close to hitting the inner fender line with near full turns from steering.
Hello
ZLBlue is offline   Reply With Quote
Old 09-20-2019, 10:45 PM   #2
Kevcamaro18
Drives: 2018 Camaro 1SS
I have bmr springs w/Camber plates on my 1ss with mag ride, my wheels are 19x10.5 front 19x11 rear with 305/30 front and back. In the front it pokes close to half inch I to was worrying about rubbing but no problems, I have one inch an a half of space to clear the front close to same in the rear with just a little more room but it beats the gap the stock springs had.!
Kevcamaro18 is offline   Reply With Quote
Old 09-21-2019, 08:09 AM   #3
Kevcamaro18
Yeah you should be just fine although I haven't had my car on a track yet, I have drove the car hard on back roads and on rough roads alot harder then most people would, to make sure the tires wouldn't rub the finders so far everything is great. I'd post a pic if I know how on here lol
Old 09-21-2019, 05:45 PM   #4
Bow Tie Fanatic
Drives: 2018 Mosaic Black Metallic ZL1 A10
I have the same setup. You won’t have any issues.
Bow Tie Fanatic is offline   Reply With Quote
