08-23-2019, 08:51 AM | #211 | |
Drives: 2019 ZL1 Join Date: Aug 2018
I install mine next weekend and align it myself. Hoping to have a formula/system so I can swap between -3.5 to -4 for autox and then something like -2.5 for street use and the math on the tie rods to go between which I think is about 1/32" per flat. |
08-23-2019, 11:37 PM | #212 | |
Drives: 2017 Hyper Blue 2SS Join Date: Mar 2017
Hyper Blue 2SS, 6MT, NPP, 6 piston Brembo, 1LE suspensions upgrade, ZL1 Seats, Wheels & Tires
08-24-2019, 12:02 PM | #213 |
Unless you DD use is toe in and track/autox toe in slight toe out AND you only change the camber a minor amount like -.5 difference, this isn't likely possible. There is a big toe change when you dial in something like -1.5-2 extra negative camber. I'll let you know but depending how many events you do a year it's not that bad to adjust the toe.
08-31-2019, 02:27 PM | #214 |
Just finished installing my plates on an otherwise stock suspension ZL1. Because my goal is to run 18x11s next year, I set the hub to minimum camber and thus maximum clearance for wheels then maxed out the camber plates. The result was a little bit of a surprised, -2.5 on both sides. This means I'll need to go back in and dial in about -1 more camber than I have now at the hub to hit my -3.5 target. Overall very pleased with the quality and they were quiet on two test drives. I'll follow up. If anyone happens to see this and knows the answer, what's the thread pitch of the bolt you can add to fine tune your hub camber? I'm going to search it now. Found it, 10x1.5 40mm hex head or regular head bolt.
08-31-2019, 05:10 PM | #215 |
NOXQCES ZL1
Drives: 2017 Camaro ZL1 Join Date: Mar 2019
I’m excited to receive & install them. I plan to set camber at -3 degrees as a baseline for daily driving and track days.
09-16-2019, 08:36 AM | #216 |
Drives: 2019 Camaro SS 1LE Join Date: Apr 2019
19SS1LE here and I'm maxed at -2.4 stock. Has anyone got a lot of track events with these at -3.5 or more? Comments on how they are holding up? I'm good with DD -2.5.
How much work at track adjustment from -2.5 to -3.5 and back would be what I'm after.
Looking for some of these:
09-16-2019, 02:12 PM | #217 | |
I just finished playing with my alignment this weekend with the plates. I have it set so at the 4th hashmark from maximum negative setting, I'm at -3.2 with 0 toe. If I max out the plate, I'm at -3.9 with 1/8" of toe out (nice to have that option and settings in between). I still have probably -.6 more negative camber at the knuckle but don't need it. Since my '19 ZL1 has the same suspension as your car, I would assume you could hit similar numbers. |
09-17-2019, 04:32 PM | #218 | |
09-18-2019, 01:18 PM | #219 |
Zero, just about 500 street miles now on them. I'll be doing a two day autox thats a bit higher speed than your normal autox with bumps in 1.5 weeks. So not hammering curbs at 100mph but should give us some indication. Given the construction, I'm not worried about them. I say this having had many sets over various cars I've autocrossed/tracked.
10-18-2019, 03:43 PM | #220 |
Still waiting for my ring with the longer studs. I was told today they will ship soon
10-18-2019, 04:39 PM | #221 |
Drives: 2016 2SS BLK A8 Vert Join Date: Dec 2017
Sorry to hear it's been such a long wait still. Sounds like a positive update though on your shipment. I'd trade my long stud slide plate "ring", and do without the strut brace, for a car that runs above 4,000 rpm on the track!! Waiting for GM/UAW strike to officially end so the dealer can get a transmission wiring harness. In other words, mine has been useless for me for at least three track events
10-18-2019, 06:34 PM | #222 |
35 autox runs on mine now, holding up strong and noise free with no changes to the adjustments on their own.
10-18-2019, 11:48 PM | #223 |
BigShow
Drives: 2017 1 Camaro + Chevy Avalanche Join Date: Oct 2014
I would like the longer studs too. Are they making them yet? I really don't like how few threads are on the cross bar mounted bolts.
10-19-2019, 10:12 AM | #224 |
They ARE making them, although sounds like only a small batch at a time. I would make the effort to call them direct with your concerns.
