Old 10-18-2016, 03:23 PM   #1
WhiteLightening
WhiteLightening's Avatar
Drives: 2016 Camaro V6 RS, 2005 Mustang GT
Question V6 launch control?
I kee reading the forums and seeing that the v6 has launch control, then another thread says we don't have launch control...would there be a way to add it to my car through programming, or something?
2016 Camaro RS V6, Custom Leather interior, Flowmaster American Thunder exhaust, x pipe
WhiteLightening is offline   Reply With Quote
Old 04-02-2018, 07:20 PM   #2
EXT03
Drives: 2018 CAMARO 2SS
On line have to press and hold the traction control to have it on
EXT03 is offline   Reply With Quote
Old 04-02-2018, 08:08 PM   #3
17rsvert
17rsvert's Avatar
Drives: 2017 HBM 2LT RS Convertible V6 A8
Can you please clarify? Does this mean that launch contol is available? What does 'on line' refer to?
17rsvert is offline   Reply With Quote
Old 04-23-2018, 10:04 AM   #4
ARCTIC
ARCTIC's Avatar
Drives: 2017 1SS convertible
On the SS, you have to be in sport or track mode. Press the traction control button twice quickly, the dash will say something about "competitive mode enabled" (don't quote me on that exactly). Push and hold the brake pedal to the floor, then stomp the gas pedal to the floor. Hold them both and your RPM's should sit right around 2,000 until you release the brake and you're off!!
Red 2017 Camaro 1SS Convertible
ARCTIC is offline   Reply With Quote
Old 04-23-2018, 08:34 PM   #5
17rsvert
17rsvert's Avatar
Originally Posted by ARCTIC View Post
On the SS, you have to be in sport or track mode....
I assume it comes with a SS. What about a V6? The owners manual just says "if equipped"
Old 04-24-2018, 12:02 AM   #6
Kairles
Kairles's Avatar
Drives: 2015 Camaro 1SS
My V6 1LE has it
Kairles is offline   Reply With Quote
Old 04-24-2018, 05:43 PM   #7
17rsvert
17rsvert's Avatar
Originally Posted by Kairles View Post
My V6 1LE has it
Anyone know about V6 without 1LE?
Old 04-25-2018, 11:12 AM   #8
Kairles
Kairles's Avatar
Have you tried it on your car?
Old 09-16-2019, 11:36 PM   #9
asnpawcio
Drives: 2018 camaro LT1 v6 - rs package
ok i have v6 1le so do you know how to use it?
asnpawcio is offline   Reply With Quote
Old 09-17-2019, 08:52 AM   #10
302Blue
302Blue's Avatar
Drives: 2017 Camaro V6 1LE
This is correct. Sport/Track needs to be enabled on V6 as well; only difference is that the RPM's hold around 4,000 rather than 2,000.
I suggest using the Competitive Stabilitrack Mode (2x traction button clicks) instead of turning everything off (press & hold traction button). I imagine it still works with everything off but Competitive Stabilitrak isn't going to limit much; especially in a straight-line so might as well keep it on for some added safety.
302Blue is offline   Reply With Quote
