02-16-2022, 10:51 PM | #11355 | |
My car is ceramic coated, which helps with quick drying before spots would form (although I'll have to get it redone, it's been almost 4 years and the coating is starting to fail in spots in terms of its hydrophobic property). The "end game plan" is to have a whole house water filter installed so I don't have to buy one just for the car, which wouldn't be fair to the family either
02-16-2022, 10:59 PM | #11356 | |
Drives: 2022 ZL1 M6/Nissan Leaf Join Date: May 2016
Just get the family one of those Zero Water pitchers and invest in just a special car wash system for the car Now that you mention it, one of my plans is to have a house built and install the whole house filtration system. I understand that showers are absolutely amazing with those systems. The water in my city is "reclaim" which is pretty disgusting. I once did an IT project for a major water bottling company, and have stopped buying bottled water since then. I've considered putting a ceramic coating on one of my cars, but I can't help feel that the paint underneath may be affected. Maybe during the Spring/Summer I'll get my Leaf done green, and then for Fall/Winter wrap it brown... |
02-17-2022, 12:04 PM | #11357 |
UK2019
Drives: Camaro 2017 2ss/eu spec convertible Join Date: Mar 2019
Adding homelink/garage door opener
I added the garage door opener to my eu spec 2017 convertible today. Though the eu cars have a very high spec (2ss with npp and mrc as options, which mine has) they don't have the garage door opener. Some devices have different frequencies in Europe but a lot run on 433mhz which the homelink system runs on. I'm using it to control my diy "mild to wild" controller for my npp but it will also work to open gates and doors.
I bought an overhead console from a coupe which came with the homelink module and buttons, didn't buy the expensive harness from gen5diy and instead soldered onto the pins of the module, used my own connector inline with where i tapped the wires (so i can swap out the module if needed). I've read guides about using the passenger airbag light as power but I tapped into the mirror harness for power and ground and tge convertible top switch for illumination and dimming control. The mirror seems to have RAP (retained accessory power) so it works with the ignition on but also for some time after the ignition has been switched off. If anyone has any questions about the wiring, happy to help. |
02-17-2022, 01:55 PM | #11358 | ||
I had the same problem with my SS (no homelink) and wound up going with a device that connected my then garage door to my cell phone. It's called a "MyQ" in the U.S. Not sure if you would have the same there. The only problem is that it won't work if the Wifi or power is down. I set up a security camera just outside so I could tell when the sorry neighbor's cat would trip the garage door sensor as the garage door was closing behind me. Hated that cat. |
02-17-2022, 03:28 PM | #11359 |
Drives: 2022 Camaro 2SS 1LE M6 Join Date: Jan 2018
Changed the oil at 500 miles with Amsoil Signature Series, and installed the Skip Shift Eliminator. A must do mod if you ask me! Now I can shift to 2nd gear whenever I freakin' feel like it 😁🥳
02-17-2022, 03:29 PM | #11360 |
I never got around to installing it on mine but god dammit did that skip shift piss me the **** off more than once
2017 ZL1 A10 2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD) |
02-17-2022, 03:37 PM | #11361 | |
02-17-2022, 06:42 PM | #11362 |
Look how frisky this fresh ZL1 owner is
Tires ain't cheap anymore, y'know
02-17-2022, 06:54 PM | #11363 |
02-18-2022, 10:32 AM | #11364 |
Drives: Chevrolet 2018 Camaro 2ss Join Date: Jan 2022
New Shoes
Just got new wheels installed ! Not the best pics but waiting for nice weather to clean her up and get some good shots.
2018 2SS |
02-18-2022, 06:42 PM | #11365 |
Drives: 2022 2SS A10 Coupe. Black + Redline Join Date: Jan 2021
02-18-2022, 07:55 PM | #11366 | |
Drives: 2018 Hyper Blue Camaro 1SS Join Date: Sep 2019
The car does look great!
1LE Replicas / Solo Axleback Exhaust/ Street Scene Front Splitter / Diode Dynamics Smoked LED Side Markers / OEM Smoked Tails & Third Brake Light / OEM Illuminated Door Sills / OEM ZL1 Side Skirts / OEM ZL1 Spoiler / OEM Black Badges / GM CAI / Soler Engineering TB/TC / Katzkin Leather / 20% Tint
02-19-2022, 05:02 PM | #11367 | |
Ha, ha darn 4 cameras on the back, didn't realize it was there until posted. Next time I'll be sure to get my whole hand |
02-19-2022, 05:23 PM | #11368 |
Drives: 2016 Camaro SS Join Date: Oct 2021
Installed 3 pair of control arms, just waiting on the rear lockout kit to do the front and rear bracing as well.
Pretty easy job.
2016 Camaro 2SS 759whp 686wtq tuned by KingLt1
Procharger D1SC - Diamond Pistons/Manley Rods BTR stage 3 cam - Circle D converter American Racing headers - Borla S-type |
