02-01-2016, 04:42 PM | #1 |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
Dyno'ing the A8 Auto
So, I know this car has torque all over the place, but it seems the car dyno's the best in 4th gear. Anyone else seeing the same results?
3rd gear hit redline way to quickly and 5th seems very drawn out and the speeds get to high.
02-01-2016, 05:31 PM | #2 |
4th wouldn't be 1:1. 6th would be 1:1 and what you would want to dyno in.
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
02-01-2016, 06:31 PM | #3 |
Drives: 2010 2SS Yellow Camaro Join Date: Jan 2010
I just dyno my 8 speed auto car today, was 388 hp and torque was 404. The guy did a second pass and was almost identical. That without the npp exhaust.
02-02-2016, 08:44 AM | #4 | |
Drives: 2016 camaro ss Join Date: Oct 2010
Most shops I've seen are dynoing the autos in 5th gear because even though 6th gear is your 1:1, it will get the tires spinning too fast for safety
2016 camaro 2SS hyper blue/Kalahari, A8, MRC, NPP, sunroof, SW headers through axleback, Circle D 3600rpm TC, Pray ported IM/TB, E85
Sold: 2002 Z28, NBM, M6, 460rwhp, 2009 HHR SS RIP : 2002 WS6 Black, A4, 355rwhp |
02-02-2016, 09:29 AM | #5 |
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
02-02-2016, 09:33 AM | #6 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
I'm confused by this. If most cars are dynoed in a 1:1 ratio, why would the 6th gen camaro be any different as far as the tires "spinning too fast for safety" goes? Any car in 1:1 will be spinning the tires at the same speed (except for tire height differences). Am I wrong?
02-02-2016, 09:55 AM | #7 | |
02-02-2016, 10:37 AM | #8 | |
gotta start considering the rear end ratio. IMO the gear selected should be closest to the final ratios we always have been using - 3.23-3.90 final ratio.(tranmission gear ratio X rear ratio) not using the gear bringing the final ratio in this range skews your results against historical data. |
02-02-2016, 11:06 AM | #9 | |
Will different final drive ratios affect the dyno readings? This one's tricky. First, there are potential discrepancies because different gears have different inertia values, generate more friction, and change the amount of tire slip. Higher numerical gears tend to be more inefficient, so as gear ratios increase numerically, power levels tend to slightly drop, particularly on an inertia dyno. When torque is multiplied by steeper gears, tire slippage also tends to increase. However, there's another, often overlooked, factor in the brew: rpm and torque are inversely related to calculating horsepower, so changing the rear axle ratio or testing in other than a 1:1 transmission gear seemingly shouldn't change the horsepower numbers. But this doesn't take into consideration the fact that changing gear ratios changes the engine's rate of acceleration. For example: We know that on an engine dyno, if you change a sweep test's acceleration rate from, say, 300 rpm/second to 600 rpm/second, the flywheel power number (bhp) drops due to the faster rate of acceleration. As an engine accelerates at a higher rate, the power required to accelerate the engine increases, and a greater portion is consumed before it gets to the flywheel. Going to numerically higher gear ratios-whether in the trans (testing in a lower gear) or in the rearend-is like increasing the rate of acceleration in a sweep test. Whether this actually changes a given chassis dyno's reported results depends on how the specific dyno manufacturer does its math. For the most consistent results, always test in the same trans gear (generally 1:1) and rebaseline the vehicle after a rear-axle ratio change. http://www.hotrod.com/how-to/additio...is-dyno-guide/
02-02-2016, 11:14 AM | #10 | |
where the 4L60E(3rd gear) used to read way lower than a M6 these newer transmissions are reading a bit higher |
02-02-2016, 11:19 AM | #11 |
In terms of driveline loss...definitely not. That whole article is a good read for anyone who wants to argue cars are underrated because a car made XXX RWHP on some dyno. There are a lot of factors to contend with.
02-02-2016, 11:45 AM | #12 | |
#becauseracecar
02-02-2016, 02:37 PM | #13 |
Lethal Camaro
Depends on the dyno and how they calc the run.
02-02-2016, 02:38 PM | #14 |
Lethal Camaro
I can try it when I head back to BBK. We only tried, 3rd, 4th, and 5th.
