01-11-2016, 01:23 PM | #1 |
Yeti's Daddy
Drives: ATS-V, Prowler, M6 V10 Join Date: Jun 2015
CAGS (Skip Shift) eliminator?
Did any vendor come up with CAGS eliminator for Gen6 Camaro yet?
If anyone knows of one, please let me know. Thanks!
2SS Nightfall Grey /Adrenaline red interior
NPP / MRC / Nav / 6 Spd 1100: 7/27/15 <SSWNNN> 3000: 9/04/15 <TPW:10/19/15> 3800: 10/19/15 <VIN: 117740> 6000: 12/16/15 |
01-11-2016, 01:27 PM | #2 |
Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
I always wondered if this was a big deal. I have read so many posts about the skip shift and I have found on my 1SS it really is not that big of a deal. I have only had it tell me to go to 4th gear once while driving and noticed you can still go to the 3rd anyways. The reason I bring this up is to maybe understand why so many people really need the skip shift eliminator? Maybe my driving style is more aggressive in first gear?
01-11-2016, 01:29 PM | #3 |
Drives: '95 Corvette, '06 Mustang, 2LT RS Join Date: Dec 2015
It's a bigger deal on cars that prevent you from going into second. I don't have an SS, but isn't the warning just that... a warning, but you can still shift into second if you want?
01-11-2016, 01:32 PM | #4 |
Drives: 2016 White 2SS on order Join Date: Mar 2011
I've seen the warning several times on the display but it's never forced me into 4th. My other Camaro's Gen 4 and 5 all made me go into 4th if I babied it.
2SS White\Red 6M
01-11-2016, 01:57 PM | #5 |
Drives: 2004 Corvette Join Date: Jan 2016
Unless it's been changed from the Corvette C5 & C6 the CAGS forces you to shift to 4th. I don't care for it in slow traffic or turning a corner slowly and want to shift out of first. You're going too slow for 4th and will lug car down.
01-11-2016, 02:02 PM | #6 |
Drives: 2017 Camaro 2SS 6MT Join Date: Aug 2006
CAGS slips out a pin in the gear box to force the gear shift from 1st to 4th. GM has used CAGS on all 6 speed manual transmission/V8 engine combos since the 1990 Corvette ZR1.
If GM has done away with this pin and just uses an advisory in the DIC, that's a win/win/win for everyone!! |
01-11-2016, 02:12 PM | #7 |
Drives: 2016 Camaro Join Date: Jan 2014
In my short drive so far in the new Camaro the 1->4 came up a few times, but easily shifted into second, third, etc. Definitely a smooth shift, wasn't forcing anything.
Curious if anyone can confirm that it locks the gear or just simply displays a warning? Maybe it was just on and I went over the RPMs to avoid it? Hmm.
2016 Camaro 2SS Manual
Hyper Blue/Ceramic White Nav, MRC, NPP, Black 5 Spokes Escort MAX 360 |
01-11-2016, 02:13 PM | #8 | ||
Past: '99 SS Camaro A4, '73 Camaro 383 A3 "Voices in your head are not considered insider information." 3800 Status - 6/16/16 (Built!) 6000 status - 6/29/16 (Delivered!) |
01-11-2016, 02:30 PM | #9 |
Ive gotten the warning and no pin but I've also gotten the warning and was forced into 4th. I would say out of the 2 months I have had it I have only gotten the warning maybe 20 times and only forced into fourth maybe 10. There was one time where I got the warning but must have shifted weird and with the clutch all the way down I made it into the second spot but it wouldnt let in it go into gear. its was grinding the gear like I was going into second without the clutch pushed. I had to pull back into neutral then fourth.
Adrenaline Red
20" 5 Spoke Black Black Side Spear Dual Mode Exhaust MRC Splash Guards 1G1FG1R74G0124089 |
01-11-2016, 02:35 PM | #10 |
Yeti's Daddy
I also noticed that it allowed me to go into 3rd, which is different than with my C5 and C6. (before putting in CAGS eliminator)
I know you can shift out of 1st either earlier or much later, to avoid it, and I know it doesn't bother some people. Well, it does bother me, so I want to find a solution to give me a FULL freedom to shift the way I want. Anyone has either harness or fuse for this yet?
01-11-2016, 03:10 PM | #11 | |
Unless the new Alpha architecture has changes so significant the old harness won't fit anymore, here's the harness for the 5th gen Camaro SS: http://www.amazon.com/CAGS-Bypass-Sk...ags+eliminator |
01-11-2016, 06:42 PM | #12 |
Drives: 2016 2ss Join Date: Aug 2015
When I first got the car I had it lock out 2nd on my a lot. Tgen I just started holding in 1st gear longer. The message will still come up but if you pass a certain rpm you can go to 2nd
01-11-2016, 06:58 PM | #13 |
Drives: 2016 Camaro 2SS Join Date: Apr 2009
I've seen the message pop up a few times but it still seems to let me shift into 2nd. I never even noticed the skip shift... I guess I'm driving to aggressive =)
2016 2SS - Summit White - MT - NPP - MRC - NAV
01-12-2016, 10:06 AM | #14 |
That's what I'm saying. Even though the message pops up it has never forced my into 4th.
2SS White\Red 6M
