TireRack
Old 10-10-2015, 11:38 AM   #1
MarouG6327
MarouG6327's Avatar
Drives: 2010 Camaro 2SS with RS package
HELP Car won't start
When started car it sounded weaker and weaker each time before it started. Finally it stopped and now it just clicks when I turn the keys. Tried jumping it and it did not work. Any ideas on what might be wrong? Thanks for the help.
2010 Camaro SS
43,000 miles
MarouG6327 is offline   Reply With Quote
Old 10-10-2015, 11:41 AM   #2
skipinminn
Chiquita
Drives: 2013 1LE/1SS YELLO1LE 1 of Only 28
call a tow truck and get it to the shop
skipinminn is offline   Reply With Quote
Old 10-10-2015, 11:59 AM   #3
Moto-Mojo
Fast Cars and Old Guitars
Moto-Mojo's Avatar
Drives: 2015 2SS RS (L99, baby!)
Did you try jumping it from the battery - in the trunk - or the terminals under the hood? I'd try directly on the battery. Did it still "click" when you jumped it? Probably just a bad connection. And some batteries only live 5 years and I see you have a 2010.
“I don’t want to belong to any club that would have me as a member.” - Groucho Marx
Moto-Mojo is offline   Reply With Quote
Old 10-10-2015, 12:00 PM   #4
splashlog48
splashlog48's Avatar
Drives: 2011 Green SS M6
All the signs of a bad battery
splashlog48 is offline   Reply With Quote
Old 10-10-2015, 12:04 PM   #5
batman53201
Account not blocked
batman53201's Avatar
Drives: The Batmobile
This
batman53201 is offline   Reply With Quote
Old 10-10-2015, 12:40 PM   #6
jcampos
jcampos's Avatar
Drives: 2014 Chevy Camaro SS
Most likely a battery issue or faulty connection(s).
Possibility of it being an issue with your alternator but, I highly doubt it.
jcampos is offline   Reply With Quote
Old 10-10-2015, 12:45 PM   #7
NJBourne23
Master of Nothings
NJBourne23's Avatar
Drives: 2010 Chevy Camaro 2LT/RS
Usually there are signs that are seen before hand that indicate the battery dying. My auto start would just click and stop, the lights would dim etc. I changed the battery and she roared back to life with no issues
2010 Chevrolet Camaro 2LT/RS
NJBourne23 is offline   Reply With Quote
Old 10-10-2015, 01:00 PM   #8
jd10013
Drives: 2012 camaro
mostly likely the battery is toast and won't even hold a charge from a jump. if it kept cranking slower and slower, why didn't you get a new one? is there any sign more indicative of a bad battery?
jd10013 is offline   Reply With Quote
Old 10-10-2015, 01:33 PM   #9
15xracing
15xracing's Avatar
Drives: 2011 Camaro ss 6.2L L99
Definetly sounds like the battery. See if it will start with a jump and if it does then there's your problem. could even be the alternator not charging the battery... Best bet would be to take it down to an auto parts store, they usually offer free testing of both.
15xracing is offline   Reply With Quote
Old 10-10-2015, 02:07 PM   #10
gbu27
Drives: 2013 ZL1
Check your terminals and make sure they are actually tight... I've helped fix more than one where the loose terminals were the issue, one wouldn't even work being jumped with the loose terminal. It needs a good connection for all that initial crank amperage
gbu27 is offline   Reply With Quote
Old 10-10-2015, 03:40 PM   #11
Jsafe17
Jsafe17's Avatar
Drives: 2010 2SS/RS 6spd LS3
Is that the original battery? If so time for a replacement
Jsafe17 is offline   Reply With Quote
Old 10-10-2015, 03:43 PM   #12
Rock-It Man
376 cubic inches of fun
Rock-It Man's Avatar
Drives: 2023 Camaro ZL1 A10
2010 car?
Probably needs a new battery.
Old 10-10-2015, 03:44 PM   #13
Red2014SS
Red2014SS's Avatar
Drives: 2014 2SS/RS Camaro
Time to pony up some cash and get a new battery.
2014 2SS/RS, L99, SW LTH w/HF Cats, GMPP Ex. Z/28 CAI, FR41s in PVD Black Chrome, Recaros, Pfadt Sway
377hp, 383tq 12.739@110.44 MPH
Red2014SS is offline   Reply With Quote
Old 10-10-2015, 04:28 PM   #14
christianchevell
old school chevy rodder
christianchevell's Avatar
Drives: 2013 2SS/RS Manual,DM exhaust,CRT
either battery or starter. And from your description I would say starter. Jumping should have started a "dead" car then it would have slowly ran out of charge if the battery could charge and would at least start eventually from the power of the other cars battery. I BTW just had to have my starter replaced as it slowly got worse.
christianchevell is offline   Reply With Quote
